22727 Discussions
Android Emulator getting terminated with Intel Arc 750 gpu
kirankoukuntla
Hi team,
with my below cpu config is
"AMD Ryzen 9 7000x... + Intel ARC GPU 750"
with virtualization enabled . (BIOS SVM enabled, and also attached snippet for confirmation).
I'm unable to get the emulator running, its crashing without much info.
with B 650M K Motherboard, 32GB Ram, NVME SSD .
request team to help me get the emulator running in this system.
please help point me URL link to correct drivers if i need to download and update from any link.
the log that i captured from first crash is here, later i'm unable to get the log as well.
INFO | Android emulator version 32.1.13.0 (build_id 10086546)
(CL:N/A) INFO | Found systemPath C:\Users\CSP\AppData\Local\Android\Sdk\system-images\android-31\default\x86_64\ WARNING |
Please update the emulator to one that supports the feature(s): Vulkan WARNING |
Failed to process .ini file C:\Users\CSP\.android\avd\Pixel_6_API_31.avd\quickbootChoice.ini for reading. init:
Could not find wglGetExtensionsString! remote 0 Maybe try updating graphics card driver, or disconnect external displays?
ERROR: init: Missing extension function wglGetPixelFormatAttribiv ERROR: init: Missing extension function wglGetPixelFormatAttribfv
ERROR: init: Missing extension function wglChoosePixelFormat ERROR: init: Missing extension function wglMakeContextCurrent
ERROR: init: Missing extension function wglGetCurrentReadDC ERROR: init: Missing extension function wglCreatePbuffer
ERROR: init: Missing extension function wglGetPbufferDC ERROR: init: Missing extension function wglReleasePbufferDC
ERROR: init: Missing extension function wglDestroyPbuffer ERROR: init: Missing extension function wglCreateContextAttribs
ERROR: init: Missing extension function wglSwapInterval ERROR: init: Missing extension function wglGetSwapInterval OpenGL Core Profile not supported.
ERROR | Could not find GLES 2.x config! ERROR | Failed to obtain GLES 2.x extensions string!
ERROR | Could not initialize emulated framebuffer INFO | Storing crashdata in: C:\Users\CSP\AppData\Local\Temp\\AndroidEmulator\emu-crash.db, detection is enabled INFO |
Duplicate loglines will be removed, if you wish to see each indiviudal line launch with the -log-nofilter flag. INFO | IPv4 server found: 192.168.0.1
INFO | Crash reports will be automatically uploaded to: https://clients2.google.com/cr/report INFO | Report ede17582-d828-4799-8764-07dcb37b22a8 is available remotely
as: 1787f954e56d4bf7, deleting. INFO | Consent given for uploading crashreport cc16223f-493e-44ce-940c-5ba396aec8be to https://clients2.google.com/cr/report INFO |
added library vulkan-1.dll INFO |
Sending adb public key [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 @Unknown] GVM is operational host doesn't support requested feature: CPUID.01H:ECX.xsave [bit 26] host doesn't support requested feature: CPUID.01H:ECX.avx [bit 28] host doesn't support requested feature: CPUID.80000001H:ECX.svm [bit 2] host doesn't support requested feature: CPUID.01H:ECX.xsave [bit 26] host doesn't support requested feature: CPUID.01H:ECX.avx [bit 28] host doesn't support requested feature: CPUID.80000001H:ECX.svm [bit 2] host doesn't support requested feature: CPUID.01H:ECX.xsave [bit 26]
host doesn't support requested feature: CPUID.80000001H:ECX.svm [bit 2] WARNING | *** Basic token auth will be deprecated soon,
please migrate to using -grpc-use-jwt *** INFO | Started GRPC server at 127.0.0.1:8554, security: Local, auth: +token INFO |
Advertising in: C:\Users\CSP\AppData\Local\Temp\avd\running\pid_1884.ini ERROR | OpenGLES emulation failed to initialize.
Please consider the following troubleshooting steps: 1. Make sure your GPU drivers are up to date. 2. Erase and re-download the emulator ($ANDROID_SDK_ROOT/emulator). 3. Try software rendering: Go to Extended Controls > Settings > Advanced tab and change "OpenGL ES renderer (requires restart)" to "Swiftshader". Or, run emulator from command line with "-gpu swiftshader_indirect". 4. Please file an issue to https://issuetracker.google.com/issues?q=componentid:192727 and provide your complete CPU/GPU info plus OS and display setup. ERROR | crashhandler_die: fatal: OpenGLES emulation failed to initialize. Please consider the following troubleshooting steps: 1. Make sure your GPU drivers are up to date. 2. Erase and re-download the emulator ($ANDROID_SDK_ROOT/emulator). 3. Try software rendering: Go to Extended Controls > Settings > Advanced tab and change "OpenGL ES renderer (requires restart)" to "Swiftshader". Or, run emulator from command line with "-gpu swiftshader_indirect". 4. Please file an issue to https://issuetracker.google.com/issues?q=componentid:192727 and provide your complete CPU/GPU info plus OS and display setup.
