22988 Discussions
Application crashes due to heap corruption caused by Intel drivers
gbhj
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
application crashes due to heap corruption caused by Intel drivers
Hardware (HW)
Brand and Model of the system.
HP Pavilion 15 Notebook PC
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
no
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP 1366 x 768 (32 bit) (60Hz) SDC4951
How much memory [RAM] in the system (see note2 below).
8192MB RAM
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
n/a
Hardware Stepp...
gbhj
there have being some forum post's with more info about this issue
https://forums.dolphin-emu.org/Thread-dolphin-crashes-when-i-play-some-games Dolphin crashes when I play some games.
and
https://forums.dolphin-emu.org/Thread-dolphin-not-working-correctly-with-my-intel-6600k Dolphin not working correctly with my Intel 6600K
gbhj
i have tested more games in dolphin and will report the call stack that showed the functions (both cdecal and fastcall are shown) that caused the application to crashall of the crashes report error c0000374 (Heap corruption) cause by the Intel driversit is also important to note that none of the crashes happen if the d3d render device (dolphin allows the user to select the device it will use to render) is set to the basic render device
wii system menu (updated callstack after driver update)
ntdll.dll!RtlReportCriticalFailure () Unknown
ntdll.dll!RtlpHeapHandleError () Unknown
ntdll.dll!RtlpLogHeapFailure () Unknown
ntdll.dll!RtlpAllocateHeap() Unknown
ntdll.dll!RtlpAllocateHeapInternal() Unknown
igd10iumd64.dll!00007ffc18a8947b() Unknown
igd10iumd64.dll!00007ffc190df017() Unknown
igd10iumd64.dll!00007ffc18dcf011() Unknown
d3d11.dll!CResource::Map<0,3>(class CContext *,class CResource
ID3D11Resource> *,unsigned int,enum D3D11_MAP,unsigned int,bool,bool,struct D3D11_MAPPED_SUBRESOURCE *)
Unknown
ID3D11Resource> *,unsigned int,enum D3D11_MAP,unsigned int,struct D3D11_MAPPED_SUBRESOURCE *) Unknown
d3d11.dll!CContext::TID3D11DeviceContext_Map_<1>(struct ID3D11DeviceContext3 *,struct ID3D11Resource
d3d11_3SDKLayers.dll!NDebug::CContext::Map(struct ID3D11Resource *,unsigned int,enum
> DolphinD.exe!DX11::D3D::ReplaceRGBATexture2D(ID3D11Texture2D * pTexture=0x000000002b578990, const
unsigned char * buffer=0x0000000025880080, unsigned int width=68, unsigned int height=48, unsigned int
pitch=72, unsigned int level=0, D3D11_USAGE usage=D3D11_USAGE_DYNAMIC) Line 20 C++
DolphinD.exe!DX11::TextureCache::TCacheEntry::Load(unsigned int width=68, unsigned int height=48,
unsigned int expanded_width=72, unsigned int level=0) Line 146 C++
DolphinD.exe!TextureCache::Load(const unsigned int stage=0) Line 633 C++
DolphinD.exe!VertexManager::Flush() Line 217 C++
DolphinD.exe!XFMemWritten(unsigned int transferSize=12, unsigned int baseAddress=0) Line 20 C++
DolphinD.exe!LoadXFReg(unsigned int transferSize=0, unsigned int baseAddress=0, DataReader src={...})
Line 233 C++
DolphinD.exe!OpcodeDecoder_Run<0>(DataReader src={...}, unsigned int * cycles=0x000000000eb6f7a4,
bool in_display_list=false) Line 188 C++
DolphinD.exe!RunGpuLoop::__l2::() Line 337 C++
DolphinD.exe!Common::BlockingLoop::Run(void) >(RunGpuLoop::__l2::void (void)
payload=void (void){...}, __int64 timeout=100) Line 106 C++
DolphinD.exe!RunGpuLoop() Line 374 C++
DolphinD.exe!VideoBackendHardware::Video_EnterLoop() Line 45 C++
DolphinD.exe!Core::EmuThread() Line 520 C++
DolphinD.exe!std::_Invoker_functor::_Call(void (void) * &&
_Obj=0x000000000040663b) Line 1410 C++
DolphinD.exe!std::invoke(void (void) * && _Obj=0x000000000040663b) Line 1478
C++
DolphinD.exe!std::_LaunchPad
(void)>,std::default_delete > > >::_Execute<0>(std::tuple
(void)> & _Tup={...}, std::integer_sequence __formal={...}) Line 239 C++
(void)>,std::default_delete > > >::_Run
(std::_LaunchPad,std::default_delete
(__cdecl*)(void)> > > > * _Ln=0x000000000014e168) Line 245 C++
(void)>,std::default_delete > > >::_Go() Line 231 C++
DolphinD.exe!std::_Pad::_Call_func(void * _Data=0x000000000014e168) Line 208 C++
ucrtbased.dll!invoke_thread_procedure(unsigned int (void *) * const procedure=0x00000000004064a6,
void * const context=0x000000000014e168) Line 92 C++
ucrtbased.dll!thread_start(void * const
parameter=0x000000001fbc4430) Line 115 C++
kernel32.dll!BaseThreadInitThunk () Unknown
ntdll.dll!RtlUserThreadStart() Unknown
new super mario brothers wii crashes after pressing 2 at the start menu
this crash and the one below crash the pixel shader compiler
ntdll.dll!RtlpAnalyzeHeapFailure () Unknown
igdusc64.dll!00007ffc14339447() Unknown
igdusc64.dll!00007ffc142e0b97() Unknown
igdusc64.dll!00007ffc147900c6() Unknown
igdusc64.dll!00007ffc1479239e() Unknown
igdusc64.dll!00007ffc1475c2d3() Unknown
igdusc64.dll!00007ffc147544e5() Unknown
igdusc64.dll!00007ffc14754d7d() Unknown
igdusc64.dll!00007ffc142e9841() Unknown
igdusc64.dll!00007ffc142e93f3() Unknown
igdusc64.dll!00007ffc142f3bdf() Unknown
igdusc64.dll!00007ffc142ef901() Unknown
igd10iumd64.dll!00007ffc18d9fcb5() Unknown
ntdll.dll!TppWorkpExecuteCallback() Unknown
ntdll.dll!TppWorkerThread() Unknown
resident evil darkside chronicles (crashes after the havok logo)
igd10iumd64.dll!00007ffc18d9fcb5() ...
Esteban_O_Intel
Please check with HP support for newer video drivers for you system, if that doesn't help you, notice that we have recently released new video drivers to support Windows 10, please visit our download center to download the video drivers: https://downloadcenter.intel.com/download/25313/Intel-HD-Graphics-Driver-for-Windows-7-8-1-10-3rd-Gen-BYT- Intel® Download Center
Eric@Intel
gbhj
the problem was initaly reported with the drivers hp package however i also installed the most recent driver 4279 the same crash happens it is importent to understand that the display driver on dx11 application is responsible for the video memory that the application uses.
there are debuging tools in intel driver for bad memory allocation https://msdn.microsoft.com/en-us/library/windows/hardware/jj542443(v=vs.85).aspx https://msdn.microsoft.com/en-us/library/windows/hardware/jj542443(v=vs.85).aspx
Allan_J_Intel1
Does this problem still occur with driver version 4300?
https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Allan.
CFera
Same bug here my cpu is i3 4150, i'm running driver 4300 and Windows 10 Pro x64.
gbhj
allan_intel
has this being replicated?
if there is the problem of you not having the games that cause the issue the section of the games can be recorded and the section that causes the problem can be made available if needed
this is used in the testing software for dolphin https://fifoci.dolphin-emu.org/about/ FifoCI
Allan_J_Intel1
I am not familiar with Dolphin FifoCI. I will check with engineering team to see if they have this matter on their list.
Allan.
ÁFern
i7 4750 and Intel Iris Pro Graphics 5200 with the driver version 4300 and same problem.
Allan_J_Intel1
Thanks for the information.
Allan.
gbhj
fixed in beta driver 4326 and by application update https://github.com/dolphin-emu/dolphin/pull/3287 D3D: Fix crash on some drivers with small textures by stenzek · Pull Request # 3287 · dolphin-emu/dolphin · GitHub
