Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Application has been blocked from accessing graphics hardware [windows 10] [Arma 3]
I have researched this a lot before posting here but it seems everything i try dosent work. I am trying to play a game called Arma 3 and every time i manage to play for about 5 -10 mins before it comes up with this error message "Application has been blocked from accessing graphics hardware" I know its not me having an intel hd 4000 as my brother can play this game perfectly (with the same laptop) on windows 8.1
I am using : Intel hd 4000 graphics card
Please help ( i know you get this a lot)
Highlighted
Arma 3 issues are still under investigation since driver version 4222. Any updates will be posted on the driver release notes.
Allan.
Highlighted
Ok thank you mate .
Do you have any idea of when the updated driver will be available ?
Anyway thanks for replying been wanting this answer for a long time
Highlighted
I do not have an estimate. I am sure it will be published on the driver release notes.
Allan.
Highlighted
Where can i find the Driver release notes ?
Highlighted
I will give you my DxDiag report to see if anyone will be able to help me because this issue is starting to get on my nerves. The game worked fine on windows 8.1
Highlighted
You could download the driver release notes on the same page you find the latest video drivers: See an example picture below:
Again, this matter has been escalated and this is under investigation and no ETA is available yet.
Allan.
Highlighted
I know your going to say "We have already discussed this" but do you think the next arma 3 update will fix a couple of problems ?
Highlighted
I do not have information about future fixes for new drivers updates. Issues fixed are published on the driver release notes.
Allan.
Highlighted
I think i may have found a fix but basically i had to change something with the arma 3 settings so that it dosent have a high cpu and disk usage, because before it was %100 usage on the disk so i messed around with the settings and i think it works . for now anyways
Highlighted
Alright, thanks for sharing this information.
Allan.
Highlighted
Ok so it seams that arma 3 has started playing up again with the same errors , do you know of anyway i can lower my cpu and disk usage as i think that may be the problem
Highlighted
The only way would be enabling Speed Step functionality, this will lower processor frequency to save power dynamically. You need to check BIOS settings.
As for disk usage, please consult with your SSD or hard drive maker.
Allan.
