Sticking your finger in the fan is not recommended.
Hello @Lipe
1. Is there any sign of overheating?
2. Please check in Arc control to verify the speed of the fans (send screenshots)
Isaac Q.
Thank you for your attention. i have not noticed over heating issues after replacing to a better airflow cabinet. iamemory temperature remains higher and goes beyond 80 degree Celsius sometimes.
Hello @Lipe
Thank you for your reply.
Were you able in Arc control to check if the speed of the fans is normal? Or were you able to configure it?
Also, please attach the following:
- Intel System Support Utility (Intel SSU) report.
- Download Intel® System Support Utility
- Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
Isaac Q.
Iam sorry if i have caused any confusion, regarding to your question about have i made any changes to fan speed is No. And i havnt noticed any issue with the graphics card. Iam only worried because one of the fan out of two on my LE arc 750 stops early than the other, i felt that i have damaged the fan by accidentally touching it while it was running. I have attached the file you have asked for.
Hello @Lipe
Based on our observations, this behavior is consistent with the expected norms. So, there is nothing to worry about it.
Since there is no issue on this thread, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Also, these GPUs have a warranty expiration time of 3 years. This Intel®️ Arc 7 three-year limited warranty applies to eligible Intel®️ Arc Cards that are packaged in authentic Intel packaging and sold to end customers as standalone components. Intel®️ Arc Cards contained within OEM systems are subject to OEM manufacturer warranties and generally are not supported directly by Intel.
Isaac Q.
