Hello interocitor,
Thank you for posting in the Intel Communities. We will help you with the coil whine issue that is present after updating the driver to version 31.0.101.5074.
To better help you on this matter, we would like to ask for the following details:
- Since the issue started after updating the Graphics driver, is the issue present if you try to roll back the driver?
- You mention that the graphics card is hot to the touch, but GPU and VRAM temperatures are normal. Do you have more information about the exact temperature reported by the card (you can use the Arc Control Telemetry data to check the information)?
- We would like to check more details about your system. Provide us with the following system reports:
• Intel®️ System Support Utility (Intel®️ SSU)
- Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
• Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Finally, here are some recommendations that you can try to reduce the sound intensity of the Coil Whine:
- Capping the FPS to the refresh rate of the monitor or lower
- Enabling V-Sync
- Double-checking the power supply efficacy
- Reduce GPU throttling/overclocking
Best regards
Jean O.
Hello interocitor,
We're keeping an eye on your topic to see if you were able to test our recommendations for the coil whine issue or compile the data we asked for so we can continue helping you.
Best regards
Jean O.
Hello interocitor,
Unfortunately, we will proceed to close this thread, as we have not heard back from you. We hope that the information we provided has been useful. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards
Jean O.
