23278 Discussions
Are Q35 and Q965/Q963 Express Chipsets OpenGL compatible?
I have two computers one is a Optiplex 755 with an Intel Q35 Express Chipset and a Optiplex 754 with an Intel Q965/Q963 chipset. Do either of these chipsets support Open GL? I am trying to install software (Blue Stacks) that checks if the OpenGL library on the PC supports the OpenGL ES 2.0 API's.
I have downloaded multiple graphics drivers for both machines and the software (Blue Stacks) still says my machines graphics card is not recognized.
Is there a specific driver that I need for Open GL? Or are these chipsets too old?
Thanks!
DArce
Valued Contributor III
The Intel® Q965 Express Chipset Family is validated to support up to OpenGL* 1.5 while the Intel® Q35 Express Chipset is validated to feature up to OpenGL* 1.3.
This information is available at the following article:
http://www.intel.com/support/graphics/sb/CS-033757.htm http://www.intel.com/support/graphics/sb/CS-033757.htm
In this case, you would need to other system that meets the minimum requirements for that application.
