All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20370 Discussions
Artefacts Intel UHD 730
vave
Hello.
There is a problem with the drivers. I have an I5 11400 processor. I am using integrated graphics. When I install the driver, artifacts appear in the browser and in the system, as well as some applications and the browser do not work well. When removed to the base windows display adapter, everything works fine.
Sys info:
Windows 11
I5 11400
WD BLUE 1TB
8GB HyperX Fury
Asus PRIME H510M-E
On windows 10 there was a problem, tried to upgrade to 11 but did not help
vave
Alberto_R_Intel
vave, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to let you know, the official statement from Intel® is that Intel® is still testing and making all arrangements to provide support for Windows* 11 as Operating System but there is no specific date yet of when that will be active or supported.
For that reason, no drivers are developed yet and what we recommend is to keep on checking the official responses from or your computer manufacturers, in this case ASUS, which does not have Windows* 11 drivers available either:
https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-H510M-E/HelpDesk_Download/
Albert R.
