All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20328 Discussions
Asus z590 tuf gaming plus wifi BSOD (DRIVER POWER STATE FAILURE)
alexlogov2014
I build new PC (Asus z590 tuf gaming plus wifi + i5 11600K + 32 GB CRUCIAL Ballistix RAM)
IThe system crashes every few hours with bsod (DRIVER POWER STATE FAILURE)
Attached mini dump files
https://1drv.ms/u/s!AhsddJcTWUdSd9g-Cnd57pcgd3c?e=zK7z0b
And screenshot https://yadi.sk/i/_Y3CSw1rMMveIA
Tried two power supplies Gigabyte 750H and Chieftronic powerplay gpu-550fc.
Also tried inserting / removing the video card ASUS radeon r7 360. And enable/disable IGPU hd 750.
However the error keeps popping up
David_G_Intel
Hello alexlogov2014
Thank you for posting on the Intel️® communities. Please share more information with us:
David G
alexlogov2014
The problem was with the second ssd and was solved by the BIOS settings
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
