Atualizei minha Intel HD 620 e agora quando clico com o botão direito na área de trabalho não aparece mais a opção de entrar nos controles gráficos da Intel, atualizei pelo driver mais recente disponível aqui no site da Intel, o que devo fazer para aparecer novamente?
Go to start, and look under Intel for the Graphics Command Center. It is no longer provided in the contxt menu (thanks to Microsoft).
Doc
The simple answer is that it is gone and you can't get it back. Once you are running a DCH-architected version of the driver, the control panel will no longer be attached to the context menu. You will see it in the Start menu, as an app, instead. This is a change that was required by Microsoft; if you don't like it, complain to them.
