So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Este es el archivo de texto que dijiste, disculpa si no tenia que pasarlo aqui es que no entiendo mucho ingles
You have the original Windows 10 release from 2015. Before you do anything else, you need to get current with windows 10. You can try using windows update, or you can go to https://www.microsoft.com/en-us/software-download/windows10 and update now.
Your graphics driver will be installed with the windows 10 update.
This windows 10 update to get current will take a long time. Best to use a LAN connection if available. Make sure you have a backup of your data. And, you may have to take several steps to get current, being as far out of date as you are.
Also, your current version of Windows 10 (1507) is not support with current drivers.
What will not stop blinking? Be specific.
(Y en modo arranque seguro va todo bien)
In the device manager, can you tell me the version of the Intel graphics driver?
Fecha del controlador: 15/8/2018
Versión del controlador: 24.20.100.6286
Quise adjuntar una foto pero no me deja, por el tamaño
Hello Nahuel,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
The problem you are reporting is very difficult to appear with a graphics driver update, chances are that your Operating System (OS) was having issues that got worse after the OS update.
I will recommend you to contact your system manufacturer (OEM) or Microsoft* so you can restore the OS to factory defaults.
Sebastian M
