22940 Discussions
BSOD igdkmd64.sys with 965 when on batteries
As long as I'm plugged in, I don't get the BSOD.
Most of the time, when I'm running on batteries, I get the BSOD with the igdkmd64.sys.
I have a Lenovo T61, Windows 7 64 bit, 4GB ram,
device manager says I have: Intel 965 Express chipset for the display.
I just recently installed windows7 64 bit on a new hard drive.
The drivers I have installed are: 15.12.75.4.64.1930 (or 8.15.10.1930 from device manager)
NICHOLAS_F_Intel
Hi lumangoy,
Can you provide your dxdiag for me please? (Start -> Run -> dxdiag -> Save All Information) Just copy and paste that info here and I'll take a look at it.
Also, what is happening leading up to the BSOD, other than it not being plugged in?
-Nic
Screen starts to flicker a couple of times. I can't move the mouse or keyboard, then eventually, the BSOD appears.
System Information
Time of this report: 12/11/2012, 17:33:42
Machine name: W7L3FF923
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 7661LU9
BIOS: Ver 1.00PARTTBLx
Processor: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 4022MB RAM
Page File: 4292MB used, 3750MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 965 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 965 Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A02&SUBSYS_20B517AA&REV_0C
Display Memory: 358 MB
Dedicated Memory: 0 MB
Shared Memory: 358 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Name: ThinkPad Display 1280x800
Monitor Model: unknown
Monitor Id: LEN4031
Native Mode: 1280 x 800(p) (60.004Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 12:22:58, 5472256 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6942-11CF-9073-BF00ADC2C535}
Vendor ID: 0x8086
Device ID: 0x2A02
SubSys ID: 0x20B517AA
Revision ID: 0x000C
Driver Strong Name: oem9.inf:Intel.Mfg.NTamd64:i965GM0:8.15.10.1930:pci\ven_8086&dev_2a02
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeVC1_B
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_S...
NICHOLAS_F_Intel
Thanks for that info lumangoy. Since you're using an OEM (Lenovo*) system, I would recommend testing out their driver to see if your issues are resolved. Here's a download for Lenovo's most up to date one; http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/7ld803ww.exe http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/7ld803ww.exe
Let me know how that goes,
-Nic
I installed some of the lenovo power utilities and I thought that fixed the problem.
Today I just got another BSOD. It usually comes after waking up from a sleep and on batteries. The screen flickers a couple of times, then the BSOD.
I believe I was on the lenovo version before, but without the power utilities installed. I will give that a try, but uninstalling the current driver and installing the lenovo version.
thanks.
