23095 Discussions
Black boarder around the HP Monior using Intel HD Graphic card
SKuru
I have purchased a new HP Pavilion 22xi monitor(22xi IPS monitor), I will come to the problem i am getting a black border found around the screen.My desktop PC is HP Ellite 7200 M. The graphic card is built in which is Intel HD Graphic card.
So please advice me to solve this problem.
Kevin_M_Intel
Hello Omn_Int,
Based on your description, I recommend you updating the bios in your system and uninstalling the current driver and install the latest graphics driver for your computer. I can provide the direct download link but I am afraid I do not know what the graphics controller is in your system. You can search for the driver at the following link:
https://downloadcenter.intel.com/default.aspx https://downloadcenter.intel.com/default.aspx
Besides the above, I recommend you installing the monitor drivers and also checking the monitor settings. Make sure you use a direct connection (no video adapter) between the monitor and the computer since this can affect the image.
