Established a new system Windows 7x86. After installing all the drivers that wereincluded, decided to upgrade the video driver. He went to the site intel downloaded the latest driver for the video adapter. The result of the computer will not boot, and left here this screen. My connection to the screen through HDMI .
Core i5 2400 3.1Ghz, s1155, 6MB, GPU Core,Asus P8H67-M B3 ,memory 2x2GB G.Skill NQ Edition Dual Channel-DDR3-1333,1. HD- Caviar Green 1TB IntelliPower, 64MB, SATA II WD10EARS , 2.Caviar Green 500GB IntelliPower, 32MB, SATA II WD5000AADS . PSU 300W.
I have exactly the same Problem with Asus P8H67-M Pro B3
i have same problem when i installing grphic driver for dg965ry my intel monterboard
is there any solution for this problem
Had the EXACT same issue on the Exact same board. I ended up booting into safe mode and rolling back the driver. After that everything was back to normal
Did some digging and it turns out that this driver (if you're using HDMI) may have handshake issues, so I'm just going to skip this "update" for now
Exactly. After a failed install new drivers, I went back to the old and everything works.So it's bad drivers.
I also enountered the same problems after a Windows Update of a newer driver as well as the newest from Intel. Reverting to the 8.15.10.2219 from the Asus website corrected the problem.
