23282 Discussions
Blurry text and Image on ASUS fx504GM new laptop
umaxo
Since I bought the computer
I noticed a problem
There is a very annoying blur in most applications
Usually during installation
And when browsing websites
I updated the drivers of the two graphics cards.
And the WIN10 from 1803 to 1809
And still have the problem
In Asus Israel I sent to the lab
And there you will answer that there is no problem
The blurring problem exists.
David_V_Intel
Hello umaxo, Thank you for posting on the Intel ® communities. I was investigating and checking the report you attached and I can see that your graphics adapter is not up to date yet, in fact, it is using a pretty old version of the graphics driver. Please check the link below and read all of the information so that you can try with a graphics driver update: https://downloadcenter.intel.com/download/28445/Intel-Graphics-Driver-for-Windows-10?product=126790 *IMPORTANT* Please read everything in that link before updating the driver since there is an explanation and description of the new Intel ® DCH drivers. It is recommended that you first check with your system manufacturer to see if they have this type of driver for your system, if they do then please install those since our drivers provided are generic, it should still work with your system with no problems but it could cause incompatibility with certain features provided by your system manufacturer. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello umaxo, I am following up with your case and see that we have not heard back from you. If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
