OS PROGRAMAS SÃO: REVIT 2017, AUTOCAD 2018 E SKETCHUP 2018.
Hello RRola5,
Thank you for submitting your question on this Intel® Community.
To better assist you, please provide us with the following information:
DxDiag* report
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
Boa tarde!
Obrigado por seu retorno.
Não tenho essa placa de vídeo em nenhuma máquina ainda, mas queria saber se ela tem capacidade para rodar os programas relacionados a minha faculdade de arquitetura (AUTOCAD 2018, REVIT 2017 e SKETCHUP 2018). Desde já agradeço!
Hello RRola5,
Thank you for your response.
Intel® UHD Graphics supports DirectX* 12. It is backward compatible, so it should work with DirectX* 11.
True Color, also known as 8-bit, is also supported.
Shader Model 5.1 is supported by this graphics controller, so it should support Shader Model 3.
I hope you find this information helpful.
Wanner G.
Hello RRola5,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
A Contingent Worker at Intel
Hello RRola5,
We have not heard back from you, so we will close this thread.
If you need further assistance, please submit a new question, we will be glad to help you.
Wanner G.
