22941 Discussions
Bug in Intel Arc graphics impacting Windows Night Light
SupportSpecialist
Recently we've taken delivery of hundreds of Intel laptops with the newer Intel Arc graphics and noticed that if you enable Windows Night Light, it makes the laptop almost unusable to certain users because of the weird color artifacting. We also have AMD counterparts of the same model and those don't have an issue. The older Intel's also don't have this issue. It's just any laptop with the newer intel arc graphics. What happens is that when you turn on the windows night light, everything turns pink and purple instead of properly adjusting the blues (all monitors, including the laptop display). No setting adjustments in the Intel Graphics Control panel help with the situation. Can Intel please do some testing and confirm this is a bug? All drivers and bios are up to date.
Someone reported this on the Microsoft forums, with no resolution: Night Light turns grey colors to pink and blue colors to purple on Windows 11 - Microsoft Q&A
DeancR_Intel
Hi SupportSpecialist,
Thank you for bringing this Intel Arc graphics issue with Windows Night Light to our attention. I understand how concerning this must be when you've deployed hundreds of laptops and are experiencing this color artifacting issue that's making systems nearly unusable for certain users.
The symptoms you're describing - where Windows Night Light causes everything to turn pink and purple instead of properly filtering blue light - is indeed unusual behavior and shouldn't be occurring with properly functioning graphics drivers. The fact that this issue is isolated to newer Intel Arc graphics systems while AMD counterparts and older Intel graphics work correctly suggests this is likely a driver compatibility issue with the Windows Night Light feature.
I appreciate you providing the reference to the Microsoft forums discussion, as this helps confirm that other users are experiencing similar issues. Since you're reporting this on behalf of an organization with multiple affected systems, would you prefer to continue this discussion via private email rather than the public forum?
Please let me know if you'd like me to contact you directly via email to discuss this Intel Arc graphics issue further and coordinate a more detailed investigation.
Dean R.
SupportSpecialist
We don't know if it's an HP issue specifically, so I was hoping others can also contribute by testing. You can email me, sure.
PatrickV_Intel
Thank you for your patience as we continue looking into a resolution for your concern.
Based on our investigation, if the issue is indeed related to the Factory Image, we recommend reaching out to your Original Equipment Manufacturer (OEM) for further assistance, as they are best equipped to support factory image-related issues.
In the meantime, you may try updating your system’s BIOS to the latest version available from your OEM's support site. This step can sometimes resolve compatibility or stability issues.
Please let us know if the issue persists after the BIOS update, or if you need help locating the correct update for your system.
Patrick V.
MAB7
Hi, Was this issue resolved? (If yes, then how?)
We are facing the same issue with a Lenovo laptop and after all driver updates and contacting Lenovo support it is still unresolved.
SupportSpecialist
This is still not resolved. We opened a case with HP. Their engineers were able to reproduce the issue in their lab. HP has a case open with Intel now.
