23083 Discussions
Can get mini pc to display on new tv
brutherb
Morning, I gave an beelink M1. I use it as my bedroom pc. It has an intel hd graphics 500 chipset.i recently won a sharp 4p-b50ej2u uhd tv. So I swapped out my older tv for the new one. I can see the beelink post and it displays on the tv 1920x10?? @60 hrtz then as it continues to boot the tv info box changes to uhd 2160 and goes blank. I can tell the tv senses the m1 but I’m not sure where the issue lies. I have tried 2 other laptops that both work in the tv with the same cord. So I’m wondering if I have to change a display setting or if the unit is just too old and doesn’t work with that tv. Thanks for any suggestions I have reduce the display output to 1024x768 in the m1 but maybe I need to increase it
MUC
Honored Contributor I
Please try changing the HDMI connection setting to “EDID1.4” in the TV menu.
