22882 Discussions
Can't adjust brightness on screen Samsung NP880Z5E-X01UB, Error code: 0x4E24 (20004) when string to start service. Windows 10
DMort1
I am trying to gt the brigightness setting to work. the following is about my comeputer
Intel(R) Content Protection HECI Service "service" will not start as well getting error 0x80070103 when.
I Was trying to update my Intel ME Interface Driver_11.0.0.1156\
Here is the log
2017:11:06 00:27:30:301:
2017:11:06 00:27:30:302: >>> Log start
2017:11:06 00:27:30:303: Mutex with given name doesn't exist. Creating new one.
2017:11:06 00:27:30:304: Obtained mutex succesfully.
2017:11:06 00:27:30:305: Single-instance mutex has been obtained
2017:11:06 00:27:30:306: Core version: 2.5.48
2017:11:06 00:27:30:307: Setup version: 2.1.14.0
2017:11:06 00:27:30:308: Command line: "C:\Users\danie\OneDrive\Downloads\SystemSoftware\Intel ME Interface Driver_11.0.0.1156\SetupME.exe"
2017:11:06 00:27:30:309: OS data: 6-2-1-0 64-bit
2017:11:06 00:27:30:310: System up time: 4474 sec
2017:11:06 00:27:30:311: Reboot pending: No
2017:11:06 00:27:30:312: Current UI language: 0409
2017:11:06 00:27:30:313: Language folder: C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp
2017:11:06 00:27:30:319: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0
2017:11:06 00:27:30:326: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0
2017:11:06 00:27:30:331: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0
2017:11:06 00:27:30:337: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0
2017:11:06 00:27:30:342: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0
2017:11:06 00:27:30:371: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
2017:11:06 00:27:30:398: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0
2017:11:06 00:27:30:404: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0
2017:11:06 00:27:30:425: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 0
2017:11:06 00:27:30:430: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0
2017:11:06 00:27:30:449: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0
2017:11:06 00:27:30:456: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 0
2017:11:06 00:27:30:478: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0
2017:11:06 00:27:30:506: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0
2017:11:06 00:27:30:546: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0
2017:11:06 00:27:30:552: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0
2017:11:06 00:27:30:557: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0
2017:11:06 00:27:30:579: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0
2017:11:06 00:27:30:584: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0
2017:11:06 00:27:30:603: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0
2017:11:06 00:27:30:608: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\sk-SK\IntelCommon.dll. Lang 041B. Rank 0
2017:11:06 00:27:30:636: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\sl-SI\IntelCommon.dll. Lang 0424. Rank 0
2017:11:06 00:27:30:660: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0
2017:11:06 00:27:30:665: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0
2017:11:06 00:27:30:670: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0
2017:11:06 00:27:30:675: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\zh-CN\IntelCommon.dll. Lang 0804. Rank 0
2017:11:06 00:27:30:680: Found C:\Users\danie\AppData\Local\Temp\IIF44CE.tmp\zh-TW\IntelCommon.dll. Lang 0404. Rank 0
2017:11:06 00:27:30:682: Loading language 0409
2017:11:06 00:27:30:702: Relaunching setup as elevated
2017:11:06 00:27:33:174:
2017:11:06 00:27:33:174: >>> Log start
2017:11:06 00:27:33:175: Opened existing mutex
2017:11:06 00:27:33:182: Dumping properties (28 total)
2017:11:06 00:27:33:183: IIF_MSILOGLEVEL=4096
2017:11:06 00:27:33:184: ME_WMI_STATE=0
2017:11:06 00:27:33:184: ME_LMS_STATE=1
2017:11:06 00:27:33:185: ME_NAC_STATE=1
2017:11:06 00:27:33:185: ME_IMSS_STATE=0
2017:11:06 00:27:33:186: ME_ICLS_STATE=1
2017:11:06 00:27:33:187: ME_VCCRT_STATE=1
2017:11:06 00:27:33:187: ME_DAL_STATE=1
2017:11:06 00:27...
Daniellmortensen: Thank you very much for contacting the Intel® Graphics communities. We are sorry to hear the laptop is not working properly.
Remember that the Intel graphics drivers are generic, meaning they might or might not work with your system, that is why we recommend to install the drivers provided in this case by Samsung. I looked on Samsung's web site for the drivers but it says that information is not available:
https://www.samsung.com/us/support/owners/product/ativ-book-8-windows-laptops-np880z5e https://www.samsung.com/us/support/owners/product/ativ-book-8-windows-laptops-np880z5e
Since the Intel® i7- 3635QM processor works with Intel® HD graphics 4000, we can try to install the latest version of the graphics driver for that controller which is 4653:
https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499 https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499
If the problem persists after that, to re-install the drivers or a BIOS update might be needed. In that case the best thing to do will be to get in contact with Samsung directly for further technical or warranty assistance:
https://www.samsung.com/us/support/ https://www.samsung.com/us/support/
Also, you can always get in contact with Microsoft directly to get further suggestions about this scenario:
https://support.microsoft.com/en-us/contactus/ https://support.microsoft.com/en-us/contactus/
Any further questions, please let me know.
Alberto R
Daniellmortensen: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
