22861 Discussions
Can't get full RGB with Intel HD 3000 connected to TV via HDMI
ÇŞeng
When I connect my Samsung TV to my Laptop via HDMI I get really poor visual quality. I looked this up and found a discussion where an intel employee responded that the issue was solved for newer models; however, I have not been able to find a work around. I didn't have this problem with my previous laptop where HDMI was controlled by Nvidia. The VGA port of this laptop is controlled by Nvidia and when I use this port I can get a smooth image but I would like to use the sound system of the TV as well.
Çağatay
Intel(R) HD Graphics 3000
Report Date: 2/14/2015
Report Time[hh:mm:ss]: 19:49:46
Driver Version: 9.17.10.3517
Operating System: Microsoft Windows 8.1(6.3.9600)
Default Language: Turkish (Turkey)
DirectX* Version: 11.0
Physical Memory: 6058 MB
Processor: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Processor Speed: 2494 MHz
Vendor ID: 8086
Device ID: 0126
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2108.5
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
Active Notebook Displays: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 06,30 inches
Vertical: 03,54 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (72 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 800 (60 Hz)
1360 by 768 (60 Hz)
1440 by 900 (75 Hz)
1440 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 09 05 01 00 00 00
30 12 01 03 80 10 09 78 0A EE 91 A3 54 4C 99 26
0F 50 54 BD EF 80 71 4F 81 00 81 40 81 80 95 00
95 0F B3 00 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 A0 5A 00 00 00 1E 66 21 50 B0 51 00 1B 30
40 70 36 00 A0 5A 00 00 00 1E 00 00 00 FD 00 18
4B 1A 51 17 00 0A 20 20 20 20 20 20 00 00 00 FC
00 53 41 4D 53 55 4E 47 0A 20 20 20 20 20 01 6F
02 03 27 F1 4B 90 1F 04 13 05 14 03 12 20 21 22
23 09 07 07 83 01 00 00 E2 00 0F E3 05 03 01 67
03 0C 00 10 00 B8 2D 01 1D 00 72 51 D0 1E 20 6E
28 55 00 A0 5A 00 00 00 1E 01 1D 00 BC 52 D0 1E
20 B8 28 55 40 A0 5A 00 00 00 1E 01 1D 80 18 71
1C 16 20 58 2C 25 00 A0 5A 00 00 00 9E 01 1D 80
D0 72 1C 16 20 10 2C 25 80 A0 5A 00 00 00 9E 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1D
* Built-in Display *
Gamma Value: 2,2
Maximum Image Size:
Horizontal: 13,39 inches
Vertical: 07,48 inches
1366 by 768 (60 Hz)
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE B0 40 00 00 00 00
00 14 01 03 80 22 13 78 EA C8 95 9E 57 54 92 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 7A 1E 56 18 51 00 16 30 30 20
25 00 58 C2 10 00 00 19 00 00 00 0F 00 00 00 00
00 00 00 00 00 25 D9 06 6A 00 00 00 00 FE 00 53
41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
00 4C 54 4E 31 35 36 41 54 31 36 4C 30 31 00 1F
* Other names and brands are the property of their respective owners. *
Jose_H_Intel1
Either graphics controller can use any of the ports at a given moment.
As per /message/230911# 230911 https://communities.intel.com/message/230911# 230911 "Full Range RGB is not available for previous generations of Intel® HD Graphics products, including 2nd Generation Intel® Core™ Processors with HD Graphics and earlier".
This is a similar thread: /message/204055# 204055 https://communities.intel.com/message/204055# 204055
