22894 Discussions
Can't get more than 640x480 over HDMI in Windows 8 with Core i3 2100 and H67 chipset
Hi!
I've run into an issue with the hdmi output on one of my computers; I can not make it display full HD or any resolution other than 640x480 over HDMI since upgrading to Windows 8. It worked just fine under Windows 7. I'm currently running version 9.17.10.2932 of the intel WDDM 1.2 driver and everything looks like it should in the device manager but I had the same problems running the built in Windows 8 drivers. I've tried setting the resolution through windows and the intel utility, I've also tried changing the refresh rate and while it is no problem changing the refresh rate I still can't change the resolution.
Anyone got any ideas or suggestions?
Fred_D_Intel
Hi Matias Falk,
I would like to know the model number of the computer and I would like to get also the graphics diagnostic report. This link will help you to generate the report http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Thanks!
