All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20373 Discussions
Can't install DCH driver for intel hd p640 on windows server 2019
RKurm1
Hello. Can you help me how to install DCH driver on windows server 2019 for p630 video card (embedded card in Xeon E-2174G)? as i know it should be compatible, but installer tells me that "computer does not meet the minimum requirements for installing software".
Also it works fine with 2019 server and uhd 630 (embedded card in i7 8700K)
AlHill
If you look at https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?v=t
you will see that the dch driver is not for your e-2174g processor, and that it is only for windows 10 64-bit.
Doc
Esteban_C_Intel
Hello RKurm1,
I would like to know if you need further assistance?
Esteban Ch.
A Contingent Worker at Intel
RKurm1
Hello. I still can't install driver on e-2174g but i made it for e-2126g. both on windows server 2019. and i still can't understand what the difference.
AlHill
The e-2174g does not support DCH, the e2126g does.
Look at https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?v=t you will see that the dch driver is not for your e-2174g processor, and that it is only for windows 10 64-bit.
Doc
RKurm1
I'm sorry but i also can't see support for e2126g in your link. where can i find all DCH compatible models ?
Esteban_C_Intel
Hello RKurm1,
Could you please make sure that your server system/server motherboard does not have any other embedded graphics controller?
Esteban Ch.
Esteban_C_Intel
Hello RKurm1,
Were you able to check the recommendations provided on the previous post? If you need further assistance, please let us know.
Esteban Ch.
Esteban_C_Intel
Hello RKurm1,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
guho
I also run Windows Server on an E-2174G and had the same issue. I found this 8th Generation NUC driver, which works on Server 2016 for the P630 embedded in the E-2174G without any modding:
intel-hd-graphics-driver-for-windows-server-2016-for-nuc8i7hnk-nuc8i7hvk.html
Hopefully it works on Server 2019 as well.
