23075 Discussions
Can't install drivers to Intel® HD Graphics for Intel® Pentium® and Celeron® Processors
BAndr5
Hello
My problem is that when I try to install drivers recommended by intel system identification utility I get an error with message that my system does not meet the minimal requirements. I have an asus t100ta, I have searched asus site but they do not have drivers for the graphic card.
this are the information form the system, I have downloaded the drivers and as I had said they could not be installed
Graphics Product [1]
http://www.intel.com/support/graphics/sb/CS-034553.htm Intel® HD Graphics for Intel® Pentium® and Celeron® Processors
Graphics Driver Version
not detected
Driver Status
http://downloadmirror.intel.com/23334/a08/Win32_b_15333.exe Newer Driver Available
3D Acceleration
Yes
Hardware Transform & Lighting Support
Yes
Video Memory
  1. 998.6 MB
Vertex Shader Support
  1. 5.0
Pixel Shader Support
  1. 5.0
Microsoft DirectX* Version
  1. 11.0
Current Graphics Resolution
1368x768
Current Color Depth
32 Bits Per Pixel
Raw EDID [1]
not detected
Thank you for your help in advance.
Kevin_M_Intel
Hi Borys,
I am sorry to hear you are having problems to install the driver. I would like to provide the driver for your unit but I will need to check some more information about your system. Can you please post your dxdiag report here?
Click Start > type dxdiag > open it > Save.
BAndr5
Hello Kevin,
thanks for fast reply. Here's the dxdiag file.
Kevin_M_Intel
Hi Borys,
Thanks for the information. I recommend you uninstalling the driver for your controller at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23406&lang=eng&OSVersion=Windows%208.1%2C%2032-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
If you continue getting the error message please try the Driver Manual Installation. Check the instructions here:
http://www.intel.com/support/graphics/sb/CS-022355.htm http://www.intel.com/support/graphics/sb/CS-022355.htm
BAndr5
Hello Kevin
Thanks for help. Unfortunately both "Win32_15338" and "Win32_b_15333" do not work, I get the same message. Please tell me, do I need to uninstall my current drivers first?
Kevin_M_Intel
Hi Borys,
It is recommendable to uninstall the current driver before installing the new one. If you have tried the driver and the manual driver installation steps my best recommendation is to contact Asus so they can provide their instructions while installing their driver or replace our unit if necessary.
BAndr5
Hi Kevin
Thank you very much for your help, I'll contact asus with this as you suggested. Once more thanks for your time
Kevin_M_Intel
