23099 Discussions
Can't play Minecraft on Windows 8
JGelb
I have recently upgraded from Windows 7 to Windows 8, and before I upgraded to Windows 8, I had no issues at all, but whenever I try to boot up Minecraft, I get this message:
---- Minecraft Crash Report ----
// I feel sad now
Time: 7/25/13 4:06 PM
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ats.O(SourceFile:297)
at ats.d(SourceFile:599)
at net.minecraft.client.main.Main.main(SourceFile:101)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.6.2
Operating System: Windows 8 (x86) version 6.2
Java Version: 1.7.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode, sharing), Oracle Corporation
Memory: 6550064 bytes (6 MB) / 26808320 bytes (25 MB) up to 518979584 bytes (494 MB)
JVM Flags: 1 total; -Xmx512M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.6.2
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Pack: Default
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
Please help!
Mobile Intel (R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1)
HP 2000 Notebook PC
Windows 8
KMaat
I had the same error in my old computer when i installed windows 8 pro when i had windows 7.
What you need to do is update your graphic drivers, and if that's not enough, you need to install Open GL for your graphic card.
Hope it helps
DArce
Valued Contributor III
What Kevin_Maatman daid is correct, however, keep in mind that the drivers for that video controller are only provided by the operating system itself, so any driver updated would only be available through Windows* updates.
At Intel's downloadcenter, there will be just drivers for Microsoft* Windows* 7 and this video controller.
