Whenever I try to install the Intel® Network Adapter Driver for Windows® 10 software update it says "No Intel(R) Network Connections found on this computer. No drivers were installed." How do I fix this and install the software update?
Do you actually have an Intel network adapter?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
