22849 Discussions
Cannot Set Quantization Range to Full (0-255) with USB-C Connected Monitor (But can with HDMI Connection)
JLaMe1
Hey all, just got a new work laptop (Dell Latitude 7480) and I have 2 ASUS VS239H-P monitors connected to it, 1 via HDMI, and the other via USB-C.
The issue I am having is that in the Intel HD graphics control panel, I can only enable Full Quantization range on the monitor connected via HDMI. In fact, most settings available on the HDMI-connected monitor are not available at all for the USB-C connected monitor (aspect ratio, IT content, quantization range). Also, if I try and enable YCbCr on the USB-C connection, the monitor goes black and drops connection.
The control panel is identifying the monitors as "Digital Television ASUS VS239"
Graphics controller is Intel® HD Graphics 620
Driver Version is 22.20.16.4799
Any ideas how to enable full quantization on the USB-C connection? First time posting, so please forgive me if I did not supply enough information...please let me know what else is needed and i will gladly provide it. Thanks.
HDMI Connected Monitor Settings
USB-C Connected Monitor Settings
Intel(R) HD Graphics 620
Report Date: Wednesday, April 4, 2018
Report Time [hh:mm:ss]: 9:38:04 AM
Driver Version: 22.20.16.4799
Operating System: Windows* 10 Enterprise (10.0.16299)
Physical Memory: 32652 MB
Vendor ID: 8086
Device ID: 5916
Device Revision: 02
Graphics Output Protocol (GOP) Version: 9.0.1056
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-7600U CPU @ 2.80GHz
Processor Speed: 2904 MHz
Processor Graphics in Use: Intel(R) HD Graphics 620
Shader Version: 5.1
OpenGL* Version: 4.5
OpenCL* Version: 2.1
Vulkan* Version: 1.0.38
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 3
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 12.2 inches
Vertical Size: 6.69 inches
Supported Modes
1920 x 1080 (60p Hz)
1920 x 1080 (48p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 09 E5 EE 06 00 00 00 00
01 1A 01 04 95 1F 11 78 0A 21 90 A6 58 54 9F 26
10 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 B0 36 80 C9 70 38 14 40 30 20
36 00 35 AD 10 00 00 1A 30 2C 80 DE 70 38 14 40
30 20 36 00 35 AD 10 00 00 1A 00 00 00 FE 00 36
48 59 31 57 80 4E 56 31 34 4E 34 37 00 00 00 00
00 00 41 11 9E 00 00 00 00 0A 01 0A 20 20 00 48
* Digital Television *
Serial Number: J1LMTF153388
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 20.08 inches
Vertical Size: 11.42 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1152 x 864 (75p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 960 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1440 x 480 (60p Hz)
1440 x 576 (50p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 69 D2 23 2C 57 02 00
04 1C 01 03 80 33 1D 78 2A D9 45 A2 55 4D A0 27
12 50 54 B7 EF 00 D1 C0 81 40 81 80 95 00 B3 00
71 4F 81 C0 81 00 02 3A 80 18 71 38 2D 40 58 2C
45 00 FD 1E 11 00 00 1E 00 00 00 FF 00 4A 31 4C
4D 54 46 31 35 33 33 38 38 0A 00 00 00 FD 00 32
4B 18 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC
00 41 53 55 53 20 56 53 32 33 39 0A 20 20 01 4D
02 03 22 71 4F 01 02 03 11 12 13 04 14 05 0E 0F
1D 1E 1F 10 23 09 17 07 83 01 00 00 65 03 0C 00
10 00 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 FD 1E
11 00 00 18 01 1D 00 72 51 D0 1E 20 6E 28 55 00
FD 1E 11 00 00 1E 01 1D 00 BC 52 D0 1E 20 B8 28
55 40 FD 1E 11 00 00 1E 8C 0A D0 90 20 40 31 20
0C 40 55 00 FD 1E 11 00 00 18 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9
* Digital Television2 *
Serial Number: J1LMTF153328
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1152 x 864 (75p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 960 (60p Hz)
1440 x 480 (60p Hz)
1440 x 576 (50p Hz)
1440 x 900 (60p Hz)
PGroo1
It's a bug in recent Intel drivers, using version 4678 will probably work. You can find it here: https://downloadcenter.intel.com/download/26836 Download Intel® Graphics Driver for Windows* [15.45]
Intel, please fix.
JLaMe1
Yes!! that worked, thank you so much!
JLaMe1
Looks like windows updated my drivers and now I lost the full quantization range setting for my usb-c connected monitor...i am now running 22.20.16.4799
I reverted and manually applied the confirmed working 4678 driver, but I once again dont have the full quantization range setting available on my hdmi to usb c connected adapter.
Drivers I am currently running are 21.20.16.4678
Report Date: Friday, May 11, 2018
Report Time [hh:mm:ss]: 10:04:11 AM
Driver Version: 21.20.16.4678
Vendor ID: 8086
Device ID: 5916
Device Revision: 02
Shader Version: 5.1
OpenGL* Version: 4.4
Vulkan* Version: 1.0.31
Active Displays: 3
Gamma: 2.2
Maximum Image Size
Supported Modes
Raw EDID:
Serial Number: KH0NG81P85YL
Gamma: 2.2
Maximum Image Size
Horizontal Size: 20.87 inches
Vertical Size: 11.81 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60i Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1600 x 900 (60p Hz)
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC DC A0 4C 59 35 38
04 1C 01 03 80 35 1E 78 EA 05 65 A7 56 52 9C 27
0F 50 54 A5 4B 00 71 4F 81 80 A9 C0 D1 C0 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 0F 28 21 00 00 1E 00 00 00 FF 00 4B 48 30
4E 47 38 31 50 38 35 59 4C 0A 00 00 00 FC 00 44
45 4C 4C 20 50 32 34 31 37 48 0A 20 00 00 00 FD
00 38 4C 1E 53 11 00 0A 20 20 20 20 20 20 01 91
02 03 17 B1 4C 90 05 04 03 02 07 16 01 14 1F 12
13 65 03 0C 00 10 00 02 3A 80 18 71 38 2D 40 58
2C 45 00 0F 28 21 00 00 1E 01 1D 80 18 71 1C 16
20 58 2C 25 00 0F 28 21 00 00 9E 01 1D 00 72 51
D0 1E 20 6E 28 55 00 0F 28 21 00 00 1E 8C 0A D0
8A 20 E0 2D 10 10 3E 96 00 0F 28 21 00 00 18 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3D
Serial Number: KH0NG81P86AL
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60i Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1600 x 900 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC DC A0 4C 41 36 38
4E 47 38 31 50 38 36 41 4C 0A 00 00 00 FC 00 44
00 38 4C 1E 53 11 00 0A 20 20 20 20 20 20 01 BF
* Other names and brands are the property of their respective owners.
Hello saiyanzzrage,
Thank you for joining the Intel Community Support.
It seems that this is a known issue. I would like to invesigate it further.
First, try installing the following version manually from our Download Center and let me know how it goes.
https://downloadcenter.intel.com/download/27680/Graphics-Intel-Graphics-Driver-for-Windows-10?product=96551
I hope forward to hearing from you.
Wanner G.
HDunn
I have the same issue with an Asus PB277Q over USB-C. Colors are washed out and it's identified as a Digital Telelvision. I also have the reduced General Settings. More info here:
Hello sycobob,
We will continue assisting you on the other thread.
https://communities.intel.com/message/543168# 543168 https://communities.intel.com/message/543168# 543168
Wanner G.
stever1
This is still ongoing with the latest version of Intel Graphics Command Centre.  Many new laptops do not have HDMI or DP ports, only USB-C ports.  Using a HDMI to USB-C adapter to connect a HDMI monitor to a USB-C port on the laptop is pretty standard when setting up external monitors.  Intel does not recognise this properly and will output low contrast.  Quantization range and colour type settings are missing when connecting via USB-C.  Why is this not resolved after several years?  Especially with this practice becoming more commonplace?  Please get your act together and provide proper support.  Thank you.
