19517 Discussions
Cannot connect BenQ MS502 DLP to laptop (Intel® UHD Graphics 620)
MGłow
I have problem with connecting the BenQ (MS502 DLP) projector to my laptop (HP ENVY Laptop 13-ad1xx). At first, everything was fine, but the second attempt was unsuccessful - "no signal". Both devices recognize each other. I am using VGA to USB-C converter cable.
Can anyone offer any advice?
Leonardo_C_Intel
Hello MGłow
Thank you for posting in the Intel Community.
  • What changes were made on the system from when it worked to now that is not working?
  • Have you tried different cables?
  • Is the input on the BenQ MS502 DLP configure correctly?
  • Can you try with different displays to see if you have the same behavior?
  • Have you made sure that the laptop is sending a video signal to the external display? (Win Key + p to select extended).
Leonardo C.
n_scott_pearson
Super User Retired Employee
I have seen all sorts of USB-C-to-VGA cables and adapters/dongles that are absolute junk and cause all sorts of problems.
