Hello I have a Toshiba P50-C00W, and a lg 34UC88-B monitor capable of 3440x1440 60Hz.
But the intgrated grepahics is only caping me at 50hz, and when I try to make a custom resolution with 60Hz i get "custom resolution exceeds the maximum bandwidth capacity" when technically HDMI 2.0 should be able to handle that .
I have installed and updated every drive I could find for both the monitor and the laptop.
Intel(R) HD Graphics 5500
Report Date: Tuesday, June 21, 2016
Report Time [hh:mm:ss]: 10:45:50 AM
Driver Version: 20.19.15.4360
Operating System: Windows* 10 Home (10.0.10586)
Default Language: English (Australia)
Physical Memory: 16298 MB
Vendor ID: 8086
Device ID: 1616
Device Revision: 09
Graphics Output Protocol (GOP) Version: 5.5.1032
Current Resolution: 3440 x 1440
Processor: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
Processor Speed: 2394 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5500
Shader Version: 5.0
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.78 inches
Vertical Size: 7.48 inches
Supported Modes
1920 x 1080 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 70 04 00 00 00 00
00 18 01 04 95 23 13 78 EA DC 95 A3 58 55 A0 26
0D 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 2E 36 80 A0 70 38 1F 40 30 20
35 00 59 C2 10 00 00 1A 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 46 36 2D 53 50 41 31 00 7B
* Digital Television *
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 31.5 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
720 x 576 (50p Hz)
720 x 480 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50p Hz)
2560 x 1080 (60p Hz)
3440 x 1440 (30p Hz)
3440 x 1440 (50p Hz)
3440 x 1440 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D F6 76 D3 EC 01 00
03 1A 01 03 80 50 22 78 EA CA 95 A6 55 4E A1 26
0F 50 54 21 08 00 71 40 81 80 81 C0 A9 C0 B3 00
D1 C0 81 00 01 01 E7 7C 70 A0 D0 A0 29 50 30 20
3A 00 20 4F 31 00 00 1A 9D 67 70 A0 D0 A0 22 50
30 20 3A 00 20 4F 31 00 00 1A 00 00 00 FD 00 38
3D 1E 5A 20 00 0A 20 20 20 20 20 20 00 00 00 FC
00 4C 47 20 55 4C 54 52 41 57 49 44 45 0A 01 53
02 03 1E F1 23 09 07 07 49 10 04 03 01 1F 13 59
5A 12 83 01 00 00 67 03 0C 00 20 00 38 40 9F 3D
70 A0 D0 A0 15 50 30 20 3A 00 20 4F 31 00 00 1A
7E 48 00 E0 A0 38 1F 40 40 40 3A 00 20 4F 31 00
00 18 01 1D 00 72 51 D0 1E 20 6E 28 55 00 20 4F
31 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00
20 4F 31 00 00 18 00 00 00 FF 00 36 30 33 4B 4B
4D 48 33 51 31 36 33 0A 00 00 00 00 00 00 00 28
* Other names and brands are the property of their respective owners.
- Tags:
- Capacity Management
Hello George:
In order to look for the proper resolution for this problem, could you please confirm if the laptop you will see on the following link is the one you are using:
http://www.mytoshiba.com.au/products/computers/satellite/p50/psptsa-00w006/specifications http://www.mytoshiba.com.au/products/computers/satellite/p50/psptsa-00w006/specifications
Is this the monitor you have:
http://www.lg.com/uk/monitors/lg-34UC88 http://www.lg.com/uk/monitors/lg-34UC88
I can see here that you installed driver version 20.19.15.4360 for Intel® HD Graphics 5500, and I found a newer driver version 15.40.25.4463, so please try to install that driver and let me know if that worked:
https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210 https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210
In addition, to be able to use that resolution you will need to use a display port, that is the one it supports 3840x2160@60Hz, if you use HDMI the following will be the max resolution: 2560x1600@60Hz
You can confirm that on the following link under graphics specifications:
http://ark.intel.com/products/85214/Intel-Core-i7-5500U-Processor-4M-Cache-up-to-3_00-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i7-5500U%20Processor%20(4M%20Cache,%20up%20to%203.00%20GHz) http://ark.intel.com/products/85214/Intel-Core-i7-5500U-Processor-4M-Cache-up-to-3_00-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i7-5500U%20Processor%20(4M%20Cache,%20up%20to%203.00%20GHz)
Alberto
Hello Alberto, thank you for the reply,
I can confirm those are both my laptop and monitor I am using, yes.
I have tried to upgrade it several times, but I keep getting an error message when trying to run the .exe getting the message
"The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer.
Setup will exit"
Assuming this is a Toshiba thing..?
As for the specs for the max resolution, why would they have a hdmi HDMI (4k2k), if the processor is only limited to 2560x1600@60Hz? :S Unless I am missing something here.
thank you again.
Hello George:
Correct, in this case the best thing to do now will be to check with Toshiba directly:
Toshiba phone number: 1 800-457-7777
Toshiba site: http://support.toshiba.com/ http://support.toshiba.com/
Even though, for processor specifications, the resolution you wanted to use is not supported, it is always recommended to have a high quality HDMI cable, because that will improve the sound and video quality in your system.
You can also try to install the driver manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Alberto
