23266 Discussions
Cant get higher than 1366X768 resolution #UHD Ver 27.20.100.9664 #Device Dell Latitude 3510
Mu_Elewa
Hello all ,
My issue is >> i cant make the resolution higher to be more 1366X768 as it displayed below
OS: Win 11 Enterprise
tried more copies of driver software with same result
tried to remove the driver with same issue
the laptop has another driver NVIDIA MX230
need solution ASAP Please if anyone has the solvent
AlHill
That is because your screen has a max resolution of 1366x768:
https://www.dell.com/en-us/shop/cty/latitude-3510-laptop/spd/latitude-15-3510-laptop/s013l351015us#tech-specs-anchor
specifically:
  • Display
    15.6" HD (1366 x 768) Anti-Glare Non-Touch, Camera & Microphone, WLAN Capable
Mu_Elewa
  • Thanks for your replay kindly check my replay with bold font
  • Display
    It is without an Intel drive setup so after setup the Intel drive it must reach more than 1366 x 768
AlHill
Your max resolution is 1366x768.   This is not an intel problem.  Contact Dell if you need further support.
Mu_Elewa
I tried already to contact Dell but they stopped supporting my version 😓
AlHill
There is nothing that can be done here.  You have a physical limitation.
Mu_Elewa
please check this screen
AlHill
So?  Are you connecting an external monitor?  If so, provide the EXACT monitor model number.
If you are connecting an external monitor, what connection/acables are you using?
This resolution does NOT apply to the laptop screen.
Mu_Elewa
yes no problem with external monitor but it is reach to 1920 only not more than
AlHill
I asked for the EXACT model number.    Have you considered that the samsung max resolution is 1920?
You need to be precise in what you are doing and to check the specifications of your equipment.   With the EXACT model number of the samsung monitor, I can look up the specs, but so can you!
Mu_Elewa
HDMI Connection with Samsung 24 inch
