23272 Discussions
Cant install intel graphics driver.
zashr
I cant install the VGA driver for my laptop, i have Acer Aspire 5930 with intel core 2 dou p7350 and running on windows xp professional sp3 ver 2002
Kevin_M_Intel
Hello Koro ,
Can you please post your dxdiag report here?
Do this:
1) Click Start
2) Click Run
3) Enter in the Open field: dxdiag
4) Hit Enter or click OK
The DXDiag panel opens. It has tabs for a number of details on your PC. Above you see DxDiag opened on the display tab.
Notice the 'Save All Information' button at the bottom. Clicking this button will save all dxdiag information into a text file. Once you have saved all the information, open the file and copy all contents of it into the post in which you explain your problem.
zashr
System Information
Time of this report: 6/29/2013, 18:56:39
Machine name: ASHRAF
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire 5930
BIOS: Ver 1.00PARTTBL
Processor: Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz (2 CPUs)
Memory: 1976MB RAM
Page File: 678MB used, 3191MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: The file d3d9d.dll is a debug version, which will run slower than the retail version.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: The file anvsnddrv.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1280 x 800 (32 bit) (1Hz)
Monitor:
Monitor Max Res:
Driver Name: vga.dll
Driver Version: 5.01.2600.0000 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 4/14/2008 15:00:00, 9344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: vga.sys
Mini VDD Date: 4/14/2008 15:00:00, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1025013F&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5610 (English)
WHQL Logo'd: Yes
Date and Size: 4/24/2008 18:13:04, 4785664 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 31
Static/Strm HW 3D Bufs: 33, 31
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: AnvsoftSound_Device
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: *anvsnddrv
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: anvsnddrv.sys
Driver Version: 1.02.0000.0000 (English)
WHQL Logo'd: No
Date and Size: 11/28/2011 14:51:44, 32896 bytes
Other Files:
Driver Provider: AnvSoft
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 64000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Registry: OK
Description: Bluetooth Hands-free Audio
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: btaudio.sys
Driver Version: 5.01.0000.3200 (English)
WHQL Logo'd: Yes
Date and Size: 3/23/2007 10:49:54, 539072 bytes
Other Files:
Driver Provider:
Cap Flags: 0xB5B
Min/Max Sample Rate: 48000, 48000
HW Memory: 0
Registry: OK
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xFFF
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
