He is wanting to adjust the Intel(R) Graphics Power Plan from Balanced to Maximum Performance.
The first picture shows the power plan that we want to adjust but we have GPO in place to not modify power settings. The second picture shows our power plan the workstations are being set to. There is no option for the Intel Graphics Settings in GPO.
Is there a registry setting that can be modified to change the Intel Graphics Power Plan to Maximum Performance, or a way to integrate this setting into GPO?
Hello JulianSorkin
I understand that you want to change the power plans of your workstations.
In this case scenario GPO's are directly managed by the OS, basically when adjusting the power plans the settings of the GPU should be adjusted as well.
We strongly recommend you to contact Microsoft* to check if there is a way to manually set the Intel Graphics Power Plan to Maximum Performance
I hope this helps.
Diego S.
Hello JulianSorkin,
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
