23096 Discussions
Change screen res, Intel HD 4000..
NRele
I have an Acer V3-571G, with Intel HD 4000 and Nvidia GeForce 630M 2GB.
Now I would like to set te screen resolution higher, but it's only possible till 1366 x 768 (60hz).
How can I make it to a higher res, so that the Windows 8.1 screen is a little bit smaller..
Thanks in advance.
Allan_J_Intel1
Thanks for joining the community.
I understand you would like to get higher screen resolution. Please try loading the latest video drivers for your computer here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000&ProdId=3712&LineId=1101&FamilyId=39 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000&ProdId=3712&LineId=1101&FamilyId=39
Please filter by operating system version and try to install the driver when it finishes downloading, to verify that your system will accept it.
Also, please attach graphics report generated within graphics control panel; see the link below to obtain the report: http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Allan.
NRele
Thanks for you reply.
This is what I have.
Intel(R) HD Graphics 4000
Report Date: Wednesday, April 23, 2014
Report Time [hh:mm:ss]: 11:40:26 AM
Driver Version: 10.18.10.3496
Operating System: Windows* 8.1 Pro(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.1
Physical Memory: 8030 MB
Processor: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Processor Speed: 2494 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2130.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: AUO26ec
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 7.48 inches
Supported Modes
1366 x 768 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF EC 26 00 00 00 00
01 13 01 03 80 22 13 78 0A D7 75 93 55 55 8D 29
24 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 0C 1C 56 A0 50 00 10 30 30 20
36 00 58 C1 10 00 00 18 00 00 00 0F 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 FE 00 41
55 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 42 31 35 36 58 57 30 32 20 56 36 20 0A 00 65
Thanks in Advance.
Allan.
Allan_J_Intel1
Thanks for the information.
Based on the graphics report, it looks like your computer will support up to 1366 x 768, it will not go lower or higher. The reason is that your computer video BIOS has been modified to support screen resolution 1366 x 768.
Allan.
