23095 Discussions
Chipset Identification Utility fails to identify chipset
EShor
I have a new Dell Poweredge T110 and need to identify the chipset so I can find the right driver to install to get round the AHCI/SATA windows installation problem (I'm trying to install Windows Server 2003).
When I run the utility it says "Failed to identify your chipset". If I run the same utility on another Dell Pc it works fine. Does anyone know if there is a reason why this utility should not work on the Dell Poweredge T110 or if there is another version of it I should be using ?
EShor
Sorry, I didn't make myself clear. What I should have said is that I need the detailed info about the chipset ie. the I/O controller. When I run the utility on the other Pc it gives me the info " Intel(R) 82801HH I/O controller hub (ICH8DH) SATA Controller found in RAID mode". That is the sort of information I am looking for, for the T110.
beh dunno then why it aint working...
But if oyu are trying to install win server 2003, why not use the drivers on teh dell website?or am i missing something?
