23257 Discussions
Como subir la memoria de video dedicada, windows 8.1
APere28
Hola, algunos juegos no me funcionan por falta de memoria de video, me dice que tengo 64mb pero creo k mi tarjeta da para mucho mas. Tengo entendido que el fabricante puede tener unos drivers para configurar eso y que mediante la BIOS no me deja. Dejo datos de mi pc y gracias de antemano.
Operating System
Operating System: Microsoft Windows 8.1(6.3.9600 Build 9600)
Physical Memory (Installed): 8 GB
Processor: Intel(R) Celeron(R) CPU N2940 @ 1.83GHz
System Type: x64-based PC
Total Installed Updates: 337 Updates - See Detailed View for more information
Display Information
Display Adapter(s): Intel(R) HD Graphics 10.18.10.3910
Motherboard Information
System Manufacturer: Acer
System Model: EA70_BM
Network Information
Network Adapter(s): Dispositivo Bluetooth (Red de área personal) 6.3.9600.18756
Realtek PCIe GBE Family Controller # 2 8.32.508.2014
Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC 2012.15.502.2014
Disk(s): WDC WD10JPVX-22JC3T0 617,47 GB (available) 6.3.9600.18758
Hello StGaara,
Thank you for joining the Intel Community Support.
Increasing your dedicated video memory may impact your system negatively and it is usually configured by computer manufacturers.
What you need to keep in mind is that the maximum amount of graphics memory depends on the available system memory, BIOS, and system settings. It is also limited by your processor; the Intel® HD graphics driver will also allocate the video memory automatically depending on various factors. Please check the table under the following section: What is the maximum amount of graphics memory or video memory my computer can use?
https://www.intel.com/content/www/us/en/support/articles/000005539/graphics-drivers.html?_ga=2.120496833.896630873.1525370747-1800354999.1520353409
In addition, computer manufacturers can add customizations and make changes that may limit or reduce the graphics memory reported by your system. You may be able to change the amount of graphics memory from the BIOS, but you need to check if the settings is available for you to modify it and probably get support from your system manufacturer.
I am including another thread that provides additional information about this issue.
https://communities.intel.com/message/527245# 527245 https://communities.intel.com/message/527245# 527245
Wanner G.
APere28
Hola de nuevo!
MI memoria grafica no aparece en la tabla que me pusiste, tengo entendido que es Intel HD Graphics Valley View pero no me da mas información el pc.
Segun la informacion del xdiag mi memoria alcanza los 1728 MB pero solo tiene dedicada 64MB que realmente es muy poco.
Mediante BIOS no me permite modificar. El fabricante me recomendó contactar con el proveedor de la gráfica, en mi caso Intel.
Dejo una copia del xdiag:
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_09391025&REV_0E
Display Memory: 1792 MB
Dedicated Memory: 64 MB
Shared Memory: 1728 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO119E
Native Mode: 1600 x 900(p) (60.062Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3910 (English)
Driver Version: 10.18.10.3910
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Gracias de antemano
Hello StGaara,
Thank you for your response.
I would like to add that in your case the graphics memory is limited by the processor. Because the processor does not have a dedicated memory chip embedded, it uses your system memory, which is the shared memory you get on the report. Having said that, the maximum shared memory your graphics controller can get is 1728 MB.
Wanner G.
Hello StGaara,
I am writing to follow up on your request.
Please let us know if you need any further help.
Wanner G.
