Hi I'm running windows 10 Home x64 with a i7-1065G7 10th generation chip connected to an VZ279 Asus Monitor right now is running at 60hz. The monitor supports 75hz so is there a way to change it to 75hz?
This should certainly be possible. Have you tried changing the refresh rate in Intel Graphics Command Center? This app should have been automatically installed (and a shortcut placed in the Start Menu) when the Intel HD Graphics driver was installed.
Hhmmm, I am not sure what is going on. You have a processor that can easily support that bandwidth. ARK says it can support:
- Max Resolution (HDMI) 4096 x 2304@60Hz
- Max Resolution (DP) 5120 x 3200@60Hz
- Max Resolution (eDP - Integrated Flat Panel) 5120 x 3200@60Hz
So it should certainly be possible to handle 1080p@75Hz.
How are you physically connecting the monitor to the laptop?
Hello Kaleidoscope,
I was checking your post and I was wondering if you were able to find a solution to your problem.
If not, I would appreciate that you could follow the steps to get the Report for Intel® Graphics Drivers and share it with me.
Please follow the steps with the monitor connected to the desired port.
Esteban D.
Hello Kaleidoscope,
We have not heard back from you. We hope that the recommendations provided by the community helped to answer your concern.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
