23092 Discussions
Control Panel Graphics Intel® HD - monitor Philips 202P4
TNiew
Hallo,
I try from a week to set right parameters of my monitor, noone can help me :(.
I use old monitor http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=202P40/94&hlt=Link_ProductInformation&mid=Link_ProductInformation&scy=US&slg=AEN Philips 202P4
Intel product I use: Control Panel Graphics Intel® HD in Windows10 64bit
Maximum resolution I can set with Graphics Intel Control Panel on my monitor is only 1600x1200 60Hz.
Why?
Philips 202P4 can be set in Windows XP up to 2048 x 1536 @ 80 Hz
Can You add right parameters to Philips 202P4 driver in next realase of Control Panel Graphics Intel® HD in Windows10 64bit?
Here You can find drivers to Win XP:
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=202P40/94&dct=DXP&did=AEN&mid=Link_Software&reldct=RXP&scy=US&slg=AEN http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=202P40/94&dct=DXP&did=AEN&mid=Link_Software&reldct=RXP&scy=US&slg=AEN
Mayby I can set custom resolution, myself?
If Yes, can You tell my How?
For now i get only information about unsuported resolution 😕
User who loves my old Philips 202P4
Tomek
P.S.
Philips 202P4 resolutions
Maximum Resolution: 2048 x 1536 @ 80 Hz
Recommended Resolution: 1600 x 1200 @ 85Hz
Factory Preset Mode:
1024 x 768 @ 75 Hz,
1024 x 768 @ 85 Hz, 1280 x 1024 @ 75 Hz,
1280 x 1024 @ 85 Hz, 1600 x 1200 @ 75 Hz,
1600 x 1200 @ 85 Hz, 1792 x 1344 @ 75 Hz,
1920 x 1440 @ 75 Hz, 1920 x 1440 @ 85 Hz
Allan_J_Intel1
Custom resolutions option is available on the graphics control panel, see instructions linked below:
http://www.intel.com/support/graphics/sb/CS-029478.htm Graphics Drivers — Custom Resolutions and Modes
Latest driver on the Intel website: https://downloadcenter.intel.com/download/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Graphics Driver for Windows® 7/8.1/10* [15.40]
Allan.
TNiew
Latest drivers installed now. Thanks.
But if I try to change custom resolution (from producer tech. specification list) i got the same info like before
>>You have exceeded the maximum value for custom resolutions.<<
Is there a method to grow up maximum value for custom resolutions?
T.
Allan_J_Intel1
The error you are reporting was already escalated. I am just waiting for any information from engineering team.
I recommend keep checking for future graphics driver releases.
In the meantime, please test a beta driver available here: https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Allan.
TNiew
Beta drivers installed. Thanks.
Monitor was recognized as Display port to VGA - DP2VGA v168 (?!)
Now I can see resolutions above 1600x1200, but I cannot set refresh rate more than 50Hz 😕
So I must have the same settings 1600x1200x60Hz as before.
T.
P.S.
Answer of Philips on my request about Drivers to WIN10:
W dniu 24.11.2015 o 11:43, mailto:pmmd_en@rsystems.eu pmmd_en@rsystems.eu pisze:
Dear Mr.Tomek,
Thank you for contacting Philips Monitors.
We are writing to inform you that you should check this with the manufacturer of the graphics card since it looks like you need to update the driver of it. The monitor itself is plug & play, so it does not need an update.
Kind Regards,
Philips Monitors
Allan_J_Intel1
Thanks for the information. At this stage, I will post updates as soon as engineering department provides details about custom resolutions.
Allan.
