22965 Discussions
Couldn't Select 1440x900 Resolution in Intel 82945G Chipset.
LG W1942S 19 Inch LCD
Native Resolution :1440x900
Graphics Driver: 8.15.10.1930
MonInfo :
Monitor
Model name............... ABC 302008WS
Manufacturer............. ABC
Plug and Play ID......... ABC8014
Serial number............ DP19052887ET
Manufacture date......... 2008, ISO week 10
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital (DisplayPort)
Color bit depth.......... 8 bits per primary color
Color encoding formats... RGB 4:4:4
Screen size.............. 650 x 410 mm (30.3 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.678 - Ry 0.309
Green chromaticity....... Gx 0.198 - Gy 0.698
Blue chromaticity........ Bx 0.146 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 29-113kHz
Vertical scan range...... 49-86Hz
Video bandwidth.......... 280MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1600p at 60Hz (16:10)
Modeline............... "2560x1600" 268.000 2560 2608 2640 2720 1600 1603 1609 1646 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1280 x 1024p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1920 x 1200p at 60Hz - VESA STD
1920 x 1440p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 5
Detailed timing # 1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing # 2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing # 3....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing # 4....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing # 5....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
Report information
Date generated........... 18-05-2016
Software revision........ 2.90.0.1002
Data source.............. Sample
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,04,43,14,80,89,DA,07,00,0A,12,01,04,A5,41,29,78,E2,8F,95,AD,4F,32,B2,25,
0F,50,54,A5,4B,00,81,80,A9,40,D1,00,D1,40,71,4F,81,00,01,01,01,01,B0,68,00,A0,A0,40,2E,60,30,20,
36,00,81,90,21,00,00,1E,00,00,00,FF,00,44,50,31,39,30,35,32,38,38,37,45,54,0A,00,00,00,FC,00,41,
42,43,20,33,30,32,30,30,38,57,53,0A,00,00,00,FD,00,31,56,1D,71,1C,00,0A,20,20,20,20,20,20,01,C4,
02,03,14,F5,4F,01,02,03,04,05,06,07,10,11,12,13,14,15,16,1F,01,1D,00,72,51,D0,1E,20,6E,28,55,00,
BA,88,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,BA,88,21,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,
10,3E,96,00,BA,88,21,00,00,18,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,BA,88,21,00,00,98,02,3A,80,18,
71,38,2D,40,58,2C,45,00,BA,88,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,24
Hi mukuls2200,
It will be necessary to narrow down the issue. Make sure your computer has the latest BIOS, chipset and graphics drivers.
If problem continues, please send me the information below.
Intel® System Support Utility report
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
How to attach a file:
-Click on reply
-Click Use advanced editor (upper right side)
-Click Attach (lower right hand)
Mike C
Hi mukuls2200,
I am following your case. Let me know if I can help you with anything else.
Mike C
