I recently built a new computer running Windows 7 Professional. When trying to run NEC's SpectraView software, I get the error message "Unable to communicate with any supported display monitors".
Here is some hardware and driver info for my machine.
MOBO: Asus Z87-A with integrated graphics processor, Intel HD Graphics support
Processor: Intel Core i7-4770
Display adaptor: Intel(R) HD Graphics 4600, driver version 9.18.10.3071
Monitor: NEC MultiSync LCD2690WUXi2(Digital), driver version 2.8.827.1917 connected to the MOBO via DVI
I contacted NEC support who told me "It's most likely possible that your Intel HD chipset does not support DDC/CI communication."
Is this the case? Is there anything I can do about it, other than buying a compatible video card?
Thank you for any help.
~Jon
Hello Wobbly,
It is important to say that our graphics controllers support DDC/CI besides some other technologies and these are automatically activated by installing the graphics driver.
You can check more information about this at the following link:
http://www.intel.com/support/graphics/sb/CS-020934.htm?wapkw=020934 http://www.intel.com/support/graphics/sb/CS-020934.htm?wapkw=020934
We recommend you installing the latest graphics driver from our side. You can download it at the following link:
At your first link - http://www.intel.com/support/graphics/sb/CS-020934.htm?wapkw=020934 http://www.intel.com/support/graphics/sb/CS-020934.htm?wapkw=020934 - it is stated that the page applies to http://support.intel.com/support/graphics/intelhdgraphics3000_2000/ 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 3000/2000. Intel(R) HD Graphics 4600 is not listed.
Also, I had an error in my first message. I have already downloaded and installed the latest driver version 9.18.10.3165 available at your second link. It did not help.
Do you have any other suggestions?
~Jon
Hi Wobbly.
The Intel® HD Graphics 4600 indeed supports DDC/CI; this is a feature that started to become available since the Intel® 82845G Graphics controller which is an extremely old graphics controller.
Please note the website is not up to date, reason why the Intel® HD Graphics 4600 does not show up; however, the processor features are not downgraded with new releases, instead, they are improved.
DDCI/CI support is already included on the driver; if any issues are presented with the software having the latest graphics driver, our best recommendation is contacting a Field Application Engineer for coding assistance as this would basically mean the software needs to be configured.
The latest graphics driver can be found at: /thread/44095 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
In order to contact a Field Application Engineer, feel free referring to any of our Intel® Authorized Distributors in order to request one. A list of Intel® Authorized Distributors can be found at the 2 following sites:
https://www-ssl.intel.com/p/en_US/techprovider/contentns?docid=493983 https://www-ssl.intel.com/p/en_US/techprovider/contentns?docid=493983
http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
