23076 Discussions
DELL U2515H Monitor miniDP using Revit goes on and off on ESPRIMO with Intel HD 4000 Graphics
JPrif
Dear Comunity,
I have a ESPRIMO P910 (D3162-A1) with Intel HD 4000 Graphics (i7-3770K) and SSD 850 EVO 500GB. On this GPU i have pluged a DELL U2515H Monitor via miniDisplayPort. When I use Autodesk Revit it happens at least once in a day that my monitor goes off and on, more times in a minute and I have to restart the workstation to get rid of this problem. The installed graphic driver ist the newest "10.18.10.4358". How can i resolve this Problem?
thanks in advance
Julian
Not applicable
Hi juliani77,
You have a branded computer, it is a Fujitsu desktop. The fully compatible drivers are provided with your system manufacturer.
I suggest you to verify if you already have the latest BIOS version, latest Chipset driver. It is a very good idea to run "DeskUpdate:Automatic driver update" utility.
http://support.ts.fujitsu.com/download/ShowFiles.asp Fujitsu Technical Support pages from Fujitsu Fujitsu Continental Europe, Middle East, Africa & India
Before running Fujitsu DeskUpdate application, uninstall and delete the current graphics driver.
Mike C
JPrif
Hi Mike,
thanks a lot for answering. i applied before all the suggested steps but the problem continuous. i think that the problem could be on the new dell monitor.
Julian
Not applicable
Hi juliani77,
Thank you for your feedback. Let me know if you need further assistance.
Mike C
