22870 Discussions
DH777KC updating OS to Win10
Fabio4
Hello, anyone knows if updating the OS from Win 7 SP1 to WIn 10 the drivers of the motherboard must be updated?
If yes, where could I find the drivers?
AlHill
Everything you need is in the Windows 10 install  and should work just fine.
Fabio4
Thank you for the response.
But what about reinstalling after formatting the PC?
AlHill
Everything you need should be in the W10 install.  And, save your W7 Key.
Go here to make the install stick.  Follow the instructions!
https://www.microsoft.com/en-us/software-download/windows10
Make sure your bios is set to UEFI mode.
When you boot the install stick, select custom install, and delete ALL PARTITIONS on the drive you are installing W10 on.  Of course, make sure you have your data backed-up before you do this.
If you have a problem, post back here.
