20987 Discussions
DH77DF motherboard to power on after AC power loss.
donglingjin
Does anyone know where in the BIOS settings of the Intel DH77DF motherboard I can find the option to set it to power on after AC power loss? I have obtained the answer already,Under Power Options, go to System Power Options and change "After Power Failure" from "Stay Off" to "Stay On" to set up automatic power on mode on Intel DH77DF motherboard.
n_scott_pearson
Here's what you need to do:
  1. Use the F2 key during startup in order to invoke Visual BIOS.
  2. Select Advanced Setup.
  3. Select Power.
  4. Select the drop-down bar for the After Power Failure parameter.
  5. Select Stay Off to have nothing happen when power is restored.
  6. Select Power On to power on and then have the O/S Started/Resumed.
  7. Click on Exit and then Yes to save this change and exit Visual BIOS.
Hope this helps,
