22671 Discussions
DQ77KB & Pentium G2030 cpu failed Digital Cable Advisor
DHuyn3
I got an error " Graphics, Fail, Your graphics card or driver doesn't support content protection" when setting up Windows 7 Media Center, I had latest board bios, drivers and freshly loaded Windows 7 pro 64 sp1 with updates. It's also failed with HDMI or HDMI to Displayport cable. Is my hardware not HDCP compliant? Any suggestions would be greatly appreciated, Thanks!
Kevin_M_Intel
Hello dkhit97,
This error may appear if the HDMI cable does not support HDCP.
Our graphics controllers support HDCP but you must use a HDMI 1.4 to have this working. This is a form of digital copy protection to prevent copying of digital audio and video content as it travels across connections
You can find more information at this link:
http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
Kevin M
DHuyn3
Hi Kevin,
I tried a 1.4 HDMI cable from Amazon but still failed. Using same cable & tv, I was able to test and passed on a Shuttle compact pc with Celeron J1900.
My older pc using DC e8200 cpu & Foxconn board with G45 chipset also passed using any hdmi cable. Thanks you for your reply, please let me know if you have any other suggestions.
Kevin_M_Intel
DHuyn3
Finally I got DQ77KB passed the DCA, problem wasn't the HDMI cables or drivers (I tried them all: original from the cd & intel web site). It works right away as soon as I change the graphic options out to Digital Television instead of the default "Clone Displays".
Kevin_M_Intel
Thank you for sharing this information.
Kevin m
