I've had lots of problems getting the integrated graphics working on Sandy bridge, now got it down to the point where everything works apart from DVI -which does seem to be a bug.
Does anyone else have the same issue and have a solution?
Using:
Windows 7 64bit (SP1 and all updates applied)
CPU Intel i5 2300
Board: Zotac H67 ITX
Drivers: 15.22.1.64.2361 (8.15.10.2361)
Monitor: Dell 2001FP
(posting in new thread as the old thread now has a misleading title.)
Original thread here:
/thread/24018?start=15&tstart=0 http://communities.intel.com/thread/24018?start=15&tstart=0
For the moment I can use the DVI input on the Dell 2001FP monitor by using a HDMI - DVI cable, which works fine.
DVI-DVI doesn't work though (although it works fine without the intel drivers installed, ie with the default windows Standard VGA adaptor drivers).
Any suggestion on how to get the normal DVI working would be a great help. Thanks.
A displayport to DVI cable doesn't help either. So I can only get a signal via the HDMI port.
Any update from Intel on these issues or does a support community really mean we are on our own?
I have the same issue.... the DVI just doesn't work on my i3 and G620.
the D-Sub works with blurry image.....
stop my windows from booting, (welcome windows then blue screen)
at safe mode, remove the driver and it works .......
the driver seems to cause a lot of issue
Thanks for the advise, i thought win7 provide latest driver, apparently not...
