Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DVI output doesn't output with Intel's drivers
What I'm trying to do is run dual monitors on an ASUS desktop with integrated Intel HD Graphics 4000. VGA output works like a champ. DVI, however, doesn't work at all regardless of what I do (swap the DVI connection between monitors, start the pc with just the DVI plugged in, ctrl+p, ctrl+alt+f12, pretty sure there was another ctrl combo, and any attempt to detect the monitor fails). That is, until I uninstall Intel's display adapter drivers. Upon reload in to Windows, the second monitor stays on and displaying (the DVI always outputs through the startup; its the Windows/Intel driver factor that kills it). I'm at a loss. The drivers are the latest 9.18.10.3257 from 7/29/2013. Even previous versions of the driver prevent DVI output. A small quirk to this issue is that hitting disable then enable for the Intel display adapter, the second monitor will magically come back on (DVI outputs like it is supposed to). There's gotta be something about the drivers that can be killed/modified to fix this. Any help is appreciated.
Tags (1)
Highlighted
Valued Contributor III
What type of DVI port do you have in that system? Is it DVI-A, DVI-I or DVI D?
You can refer to this URL for information on how to identify it:
http://commons.wikimedia.org/wiki/File:DVI_Connector_Types.svg http://commons.wikimedia.org/wiki/File:DVI_Connector_Types.svg
Are you using any type of adapter, converter or any other device in between such as a KVM, AV receiver etc.?
If you are using a straight cable, is it the same in both ends?
Highlighted
Its a DVI-D dual link cable. I'm just running straight cable from the monitor to the pc. The monitor is a HP L1750, which receives DVI-D dual link. Just checked the cable and all of the pins are straight and shiny.
Highlighted
While using the DVI-D and VGA connected to the system, please generate the dxdiag report from your system and copy paste it here.
Also paste the system report generated by the Intel(R) Graphics and Media control panel, to generate the report, follow the instructions here:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics | Intel(R) Graphics Driver Report
Additionally, please specify the model of the monitors being used, the BIOS version of the system, and the model of the motherboard you have.
Highlighted
The monitors are both HP L1750. The BIOS version is 3514. Motherboard is P8H61-M LX2 Rev. 3.00. Dxdiag
------------------ System Information ------------------ Time of this report: 10/25/2013, 13:04:29 Machine name: SHERRI-PC Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532) Language: English (Regional Setting: English) System Manufacturer: ASUSTeK Computer INC. System Model: CM6731_CM6431_CM6331 BIOS: BIOS Date: 06/27/12 11:20:43 Ver: 35.14 Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz Memory: 8192MB RAM Available OS Memory: 7900MB RAM Page File: 2404MB used, 13392MB available Windows Dir: C:\windows DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.01.7601.17514 64bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Intel(R) HD Graphics 4000 Manufacturer: Intel Corporation Chip type: Intel(R) HD Graphics Family DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_844D1043&REV_09 Display Memory: 1760 MB Dedicated Memory: 256 MB Shared Memory: 1504 MB Current Mode: 1280 x 1024 (32 bit) (60Hz) Monitor Name: HP L1750 LCD Monitor Monitor Model: HP L1750 Monitor Id: HWP26E9 Native Mode: 1280 x 1024(p) (60.020Hz) Output Type: HD15 Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32 Driver File Version: 9.18.0010.3257 (English) Driver Version: 9.18.10.3257 DDI Version: 11 Driver Model: WDDM 1.1 Driver Attributes: Final Retail Driver Date/Size: 7/29/2013 21:28:52, 8653312 bytes WHQL Logo'd: Yes WHQL Date Stamp: Device Identifier: {D7B78E66-4222-11CF-4A7F-47A4B4C2C435} Vendor ID: 0x8086 Device ID: 0x0162 SubSys ID: 0x844D1043 Revision ID: 0x0009 Driver Strong Name: oem32.inf:IntelGfx.NTamd64.6.1:iIVBD_w7:9.18.10.3257:pci\ven_8086&dev_0162 Rank Of Driver: 00E02001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled ------------- Sound Devices ------------- Description: Speakers (VIA High Definition Audio) Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_0397&SUBSYS_10438415&REV_1000 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: viahduaa.sys Driver Version: 6.00.0001.9500 (English) Driver Attributes: Final Retail WHQL Lo...
Try using the latest BIOS for your system posted here:
http://www.asus.com/Desktops/CM6731/# support CM6731 - Desktops - ASUS
And check the information posted here:
