20623 Discussions
Debian does not do 4K on Intel 620
AKrue
Please help me with this issue, described in all length over there: http://forums.debian.net/viewtopic.php?f=7&t=133136 Debian User Forums • View topic - 4K resolution in Debian stretch (testing) on INTEL graphics?
In short:
Got a 4K screen working on Windows,
on a Dell 13-5378 (Inspiron 13 5000 i5).
So I can see 3840 pixels × 2160 (HDMI, 30Hz).
Now same hardware, with Debian stretch (testing)
... I only get a max resolution of 2048 x 1152
The experts in the Debian forum have already tried to help me, but so far, no success.
Any idea what to do?
Thanks!
AKrue
uname -a
Linux Dell13-5378 4.9.0-3-amd64 # 1 SMP Debian 4.9.30-1 (2017-06-04) x86_64 GNU/Linux
inxi -GSM
System: Host: Dell13-5378 Kernel: 4.9.0-3-amd64 x86_64 (64 bit) Desktop: Cinnamon 3.2.7
Distro: Debian GNU/Linux 9 (stretch)
Machine: Device: laptop System: Dell product: Inspiron 13-5378 serial: ...
Mobo: Dell model: 0P87CH v: A00 serial: .... UEFI: Dell v: 1.6.1 date: 02/13/2017
Graphics: Card: Intel Device 5916
Display Server: X.org 1.19.2 drivers: modesetting (unloaded: fbdev,vesa)
tty size: 136x28 Advanced Data: N/A for root
xrandr
Screen 0: ....
HDMI-1 connected primary 2048x1152+1920+0 (normal left inverted right x axis y axis) 621mm x 341mm
2048x1152 60.00*
1920x1200 59.95
1920x1080 60.00 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1600x1200 60.00
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
akrueger: Thank you very much for joining the Intel® Graphics communities.
Just to let you know, Intel tested their products using Windows as an operating system, so there is no documentation regarding how Debian works, let me apologize for that. You mentioned that you already visit the Debian forums, not sure if this is the same site, but on the link below you will be able to get further peer's assistance on this matter:
http://www.debianuserforums.org/ http://www.debianuserforums.org/
Any further questions, please let me know.
Alberto R
AKrue
Hello Alberto, thanks a lot for your answer.
yes, sure.
But I cannot believe that in the Intel mega-corporation that there is not a single Linux expert.
I think there is.
No need to apologize.
Just spend 0.01% of your profits on a small dedicated Linux team - it can only do you good.
> http://www.debianuserforums.org/ debianuserforums.org/
Thank you very much, good idea. I have now also crossposted into that forum.
However, at first sight, that looks about 40 times smaller than the forums.debian.net
Thanks anyways
Hi akrueger: You are welcome. I will send your suggestions to the proper department so they can be ware for your comments.
Hopefully you will find a information needed in those forums.
Alberto R
AKrue
Thanks a lot.
Any reply from that department?
akrueger: You are welcome. Just to let you know, basically what I did was to send your suggestion about having a Linux team to that department so they can be aware of your feedback. In that regard they are the ones that will consider that suggestion to implement it or not.
Alberto R
AKrue
I was able to upgrade the kernel to 4.12
See:
http://forums.debian.net/viewtopic.php?f=7&t=133136&start=30# p652986 Debian User Forums • View topic - 4K resolution in Debian stretch (testing) on INTEL graphics?
http://forums.debian.net/viewtopic.php?f=7&t=133136&start=30# p652986 http://forums.debian.net/viewtopic.php?f=7&t=133136&start=30# p652986
But I still only see 2048 x 1152 pixels.
What to do?
What do your inhouse Linux experts say?
Andreas
akrueger: Perfect, it is great to hear that you were able to do the upgrade. In regard to your inquiry, in this case, the best thing to do will be to wait for the response from Debian forums, they should be able to provide further assistance on this subject.
Alberto R
