- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I am a software developer working at a 3D data visualisation company. We are experiencing a driver crash in Intel HD 620 / 630 graphics devices which is affecting our userbase.
Have narrowed it down to an issue that causes the driver to crash & reset in Google Chrome when using WebGL on Intel HD 630 hardware. I have a pretty solid reproduction of the crash however no way to determine what is causing the issue.
Who can I talk to about this? We are happy to provide samples to reproduce issues but we have no idea how to work around this driver crash. It appears to be affecting Intel hardware only.
You can observe crashes by visiting https://demo.scichart.com/javascript-realtime-ghosted-traces-chart in Google Chrome on Windows 10 with Intel UHD 630 hardware and leaving this application to run
Thanks and regards,
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi @andrewbt
Hope you are doing well, thanks for posting your query.
Hope this information helps : community.intel.com/t5/Graphics/intel-hd-graphics-630-crashing-windows-10/m-p/616307#M72115
Please let me know how it goes.
Shvm_ReX
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Unfortunately it doesn't, I'm talking about an issue that affects customers of my software who have Intel HD hardware. We've tested on a number of devices (laptops, desktop computers) with Intel HD 620/630 and all crash.
This post seems relevant, looks like the Intel HD 630 drivers have quite a lot of issues?
https://community.intel.com/t5/Graphics/OpenGL-Windows-drivers-for-Intel-HD-630-leaking-GPU-memory-when/m-p/1276515
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello andrewbt
To investigate this request, please share with us the following information:
- Graphics/processors tested
- Does this happen with different drivers? Please list their version.
- Detailed description of the problem and steps to replicate it
- What version of Chrome did you test?
- Is this new software publicly available for download?
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Intel® Graphics Command Center report
- "Support" > "System Diagnostic" > "Generate Report
David G
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi David, thank you for the reply,
GPUs tested:
We have a selection of GPUs in the company. We've tested nVidia GPUs (fine), Radeon (fine) and Intel Iris Pro (fine) and Intel HD. The only one which crashes is the Intel UHD 630
Drivers:
At present I have Driver version 27.20.100.9466. Before that I had an older version, but I updated to the latest. The crash occurred with both versions.
Chrome:
Latest version 90.0.4430.212 64-bit official build.
Is the software publicly available:
No, but I can make that happen. Let me work on it and I will reply back when done.
SSU Results & Graphics Command Center report
Please find them attached. Note my computer is dual-GPU (has nVidia 2070 and Intel HD 630). In order to perform tests I have unplugged the nVidia from the monitor and plugged the monitor into the Intel HDMI output. I've checked in chrome browser by going to chrome://gpu that the browser is using the Intel GPU.
Thanks!
-Andrew
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi @David_G_Intel a further update on the above.
This webpage now reproduces the crash. If you run it in latest Chrome browser on Intel UHD 630 and driver 27.20.100.9466
https://demo.scichart.com/webgl-intel.html
Leave it running for a few minutes and it will cause a GPU driver restart
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thank you for the information provided Andrew. We are working on this request, the updates will be posted on the thread.
David G
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
After verifying the information provided, since this is a software under development, please check directly with the Intel® Developer Zone. You will find assistance and resources on there:
David G
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
