22974 Discussions
Defective Intel HD 530 Display Adapter Card on New Laptop???
LKrau
Just spent many hours migrating from old laptop to a brand new one. The final thing I wanted to do was an HDMI hook up to an external monitor. The monitor wasn't being recognized no matter what I tried. It had worked fine with my old laptop. A tech support guy took over my new laptop via remote control, did all kinds of things including BIOS update and driver uninstall/reinstall (he said the driver would not reinstall because the HD 530 card was not recognized), and concluded that the HD 530 card was defective and that I needed to get a warranty replacement of the new laptop. I'm waiting for delivery of the replacement and thinking about the many hours it'll take to do another migration. In the meantime, I decided to do some trouble-shooting myself. I replaced the HDMI cable, which was new, with an old one I had, and was surprised to see the external monitor come to life. It's working just fine. The device manager doesn't indicate a problem with the HD 530. Below is the graphics report. I'm thinking that the HD 530 card is not defective. Seeking expert opinion.
______________________________________________________
Intel(R) HD Graphics 530
Report Date: Saturday, April 02, 2016
Report Time [hh:mm:ss]: 3:04:03 PM
Driver Version: 20.19.15.4360
Operating System: Windows* 7 Professional (6.1.7601)
Default Language: English (United States)
Physical Memory: 12124 MB
Vendor ID: 8086
Device ID: 191B
Device Revision: 06
Video BIOS: 1024.0
Current Resolution: 1360 x 768
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Processor Speed: 2592 MHz
Processor Graphics in Use: Intel(R) HD Graphics 530
Shader Version: 5.0
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 22.83 inches
Vertical Size: 12.6 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720...
LKrau
Thanks, Allen.
I read the Notes for ver 4404 and it does appear to address issues I experienced for my particular laptop's hardware. I've done quite a bit of messing around to get a rather stable way to use my external monitor and also its audio, with laptop lid closed. I don't shut off the laptop, otherwise on boot up it fails to detect the external monitor. So I just shut off the external monitor and let the laptop go into a time-out sleep. And I wake it up by powering the monitor and clicking the mouse.
I cancelled the order for the replacement laptop today, as I'm convinced that I don't have a bad HD 530 graphics card.
I'm a little hesitant to participate in a beta test, much as I'd like to get all of this working as it should. But, I may do so, if I can call someone at Intel if support is needed or to get me back to where I was.
Can you tell me when this version is likely to be through with beta testing?.
Len
LKrau
Allan,
I ran the Intel Driver Update Utility and got the result below. Do you think there's much risk in going ahead with the 4404 install? It's rather evident that the mfgr isn't up to date on driver updates.
I have tried beta driver on several systems and did not experience issues. Driver 4404 will address issues linked on the driver release notes.
Allan.
