23279 Discussions
Delay when typing and in when displaying images, HD Graphics 3000
pEspe
I have a Dell L702x laptop, running under Windows seven.
I bought this laptop (a a new one) in 2012.
The configuration of the laptop is as follows :
Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2395 MHz
BIOS/Date Dell Inc. A19, 07/09/2012
NVIDIA GeForce GT 550M
Intel(R) HD Graphics 3000
RAM : 8 Go
TOSHIBA MK2561GSYN SCSI Disk Device : 232,89 Go (90 Go free)
I use this laptop for surfing the web, writing and receiving emails.
Since I bought the laptop, I have been facing the following problem :
- there is a random latency from 0 to 1 second, when displaying an image, or when taking into account the typing of a character.
I tried many things to solve the matter but with no success, such as :
- upgrading the various drivers
- re-installing Windows seven
Finally, I wonder that I have to come to the conclusion that the problem is inherent to the HD Graphics 3000 card.
The information about the HD Graphics 3000 card is as follows :
total available graphics memory : 1696 Mo
dedicated video memory : 64 Mo
dedicated video memory : 0
shared system memory : 1632 Mo
In the resource monitor the data are the following ;
- processor utilization : low (less that 10%), max frequency : 30 to 40%
- Hard disk : very often at 100% of activity usage
- memory used : around 30%
My questions are as follows :
- do you think that the trouble come from HD Graphics 3000 card ?
- in case it comes from the Intel card, is there a way to improve the matter ?
- could the trouble come from the HDD ? Would replacing it by a SSD be useful ?
I thank you very much in advance for any reply.
Patrick
EstebanA_C_Intel
Hello, patrmich:
I would like to know if you have tested the behavior of your system with the following drivers.
1. OEM drivers: http://www.dell.com/support/home/us/en/04/product-support/product/xps-l702x/drivers/advanced Product Support | Dell US (make sure you select the correct OS and version.
2. Default driver from Windows 7* (uninstall the current drivers for display adapter,Intel® HD Graphics, and let the system reboot.)
3. Intel® generic drivers: https://downloadcenter.intel.com/product/81500/Intel-HD-Graphics-3000-for-2nd-Generation-Intel-Core-Processors Drivers & Software (also make sure you select the correct OS and version 32/64-bit)
If found this that could also be the issue you are encountering with, this is related to FilterKeys.
https://support.microsoft.com/en-us/kb/894040 https://support.microsoft.com/en-us/kb/894040
I look forward to your outcome with this.
Esteban C
