22968 Discussions
Dell Precision M3800 - HDMI output resolution 2560x1440 (Intel HD 4600)
mlee56
Hi all,
I have a Dell Precision M3800 which i have connected to two DGM IPS-2701WPH LCD Monitors (native 2560x1440 60Hz). The Dell provides two video output ports 1 x mini DisplayPort and 1 x HDMI.
Both monitors will display out the native resolution while being powered off the MiniDP port. However from the HDMI port the laptop will only display to 1920x1080 and nothing higher.
Using a Apple MacBook Pro the monitors work fine using HDMI at the full 2560x1440 resolution. so i know it isnt a problem with the monitor end.
Things i have tried,
  1. customapp mapping a resolution to 2560x1440 at 30Hz = black screen, and anything higher (refresh rate) - i get a dialog box stating - The custom resolution exceeds the maximum bandwidth capacity.
  2. updated to the latest Dell video driver
  3. manually installed the latest Intel Video Driver
None of these have resolved the issue. below is a copy of the Intel video report, any advise would be greatly appreciated.
Thanks in advanced
Intel(R) HD Graphics 4600
Report Date: 9/5/2014
Report Time[hh:mm:ss]: 10:53:11
Driver Version: 10.18.10.3345
Operating System: Microsoft Windows 8.1 Pro(6.3.9600)
Default Language: English (United Kingdom)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 16193 MB
Processor: Intel(R) Core(TM) i7-4702HQ CPU @ 2.20GHz
Processor Speed: 2195 MHz
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
GOP Version: 5.0.1032
Current Graphics Mode: 3200 by 1800
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
Active Notebook Displays: 1
* Digital Display *
Monitor Name: Boevt Terra2760WLED
Display Type: Digital
Connector Type: HDMI
Serial Number: WOR2760
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Digital Display
Maximum Image Size:
Horizontal: 23.62 inches
Vertical: 13.39 inches
Monitor Supported Modes:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (72 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 720 (60 Hz)
1280 by 1024 (75 Hz)
1440 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
2560 by 1440 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 5D F2 60 27 00 00 00 00
01 16 01 04 A3 3C 22 78 FE EE 95 A3 54 4C 99 26
0F 50 54 A5 CB 00 71 4F 81 C0 81 80 95 00 B3 00
D1 C0 01 01 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 55 50 21 00 00 1A 00 00 00 FF 00 4E 41 0A
20 20 20 20 20 20 20 20 20 20 00 00 00 FD 00 17
4C 0F 63 19 00 0A 20 20 20 20 20 20 00 00 00 FC
00 54 42 44 0A 20 20 20 20 20 20 20 20 20 01 16
02 03 1F F1 4C 01 02 03 04 05 07 90 12 13 14 16
1F 23 09 07 07 83 01 00 00 65 03 0C 00 10 00 02
3A 80 18 71 38 2D 40 58 2C 45 00 FE 1F 11 00 00
1E 01 1D 80 18 71 1C 16 20 58 2C 25 00 FE 1F 11
00 00 9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00 FE
1F 11 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96
00 FE 1F 11 00 00 18 01 1D 00 BC 52 D0 1E 20 B8
28 55 40 E8 12 11 00 00 1E 00 00 00 00 00 00 07
* Built-in Display *
Monitor Name: Generic PnP Monitor
Connector Type: Embedded DisplayPort
Serial Number: SHP13F8
Gamma: 2.2
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 13.78 inches
Vertical: 07.48 inches
3200 by 1800 (60 Hz)
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4D 10 F8 13 00 00 00 00
22 17 01 04 A5 23 13 78 0E DE 50 A3 54 4C 99 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 CD 91 80 A0 C0 08 34 70 30 20
35 00 5A C2 10 00 00 18 00 00 00 10 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 36
52 47 57 30 80 4C 51 31 35 36 5A 31 00 00 00 00
00 02 01 03 28 00 12 00 00 0B 01 0A 20 20 00 1B
* Other names and brands are the property of their respective owners. *
Jose_H_Intel1
Hi Bun, I noticed in the report you shared that Windows* loads a driver for a different monitor model (Boevt Terra 2760WLED).
http://forums.overclockers.co.uk/showthread.php?p=23485173 Driver for DGM IPS-2701WPH ? - Overclockers UK Forums
You may want to ask the monitor manufacturer for a correct driver.
I also suggest you trying the following:
mlee56
Hi Joe, Thanks for the suggestion on the video driver. I have tried this and in device manager it reports the driver version as Intel(R) Graphics Driver: 10.18.10.3907; which is the one I installed a week ago.
On the driver for the monitor, i think i will be out of luck as i dont think DGM has ever release a driver for any of there monitor equipment. http://www.digimate.com/en/index.asp http://www.digimate.com/en/index.asp
Either way, surely the intel should be reading the EDID value and reporting the correct selectable options to the O/S.
Cheers
MB
Jose_H_Intel1
Perhaps you can try escalating the case with DGM. I do not think we are getting the correct EDID since the operating system is not getting the correct monitor model.
You may also try updating Windows* and check for a possible V-BIOS update within the system BIOS.
RSanc13
I'm having the same problem as the original poster. I'm using the same monitor (DGM) with the same panel (boevt). Windows downloads the driver, but it's still not allowing full resolution.
However, when using Xubuntu, or other Linux distros, there is no problem with the monitor being recognised and the full resolution being made available. If it is a case of not getting the correct EDID, wouldn't the same problem be found under Linux?
RSanc13
Bumping this thread with some data. I used Monitor Asset Manager to pull this data from the DGM.
Monitor
Model name............... TBD
Manufacturer............. WOR
Plug and Play ID......... WOR2760
Serial number............ NA
Manufacture date......... 2012, ISO week 1
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital (HDMI-b)
Color bit depth.......... 8 bits per primary color
Color encoding formats... RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
Screen size.............. 600 x 340 mm (27.2 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar
Firmware revision........ 1.0
Firmware flags........... 0x0000005A
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 67.20kHz, 59.70Hz
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-99kHz
Vertical scan range...... 23-76Hz
Video bandwidth.......... 250MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1440p at 60Hz (16:9)
Modeline............... "2560x1440" 241.500 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing # 1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing # 2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing # 3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing # 4....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing # 5....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 08/10/2014
Software revision........ 2.90.0.1000
Data source.............. Real-time 0x0031
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,5D,F2,60,27,00,00,00,00,01,16,01,04,A3,3C,22,78,FE,EE,95,A3,54,4C,99,26,
0F,50,54,A5,CB,00,71,4F,81,C0,81,80,95,00,B3,00,D1,C0,01,01,01,01,56,5E,00,A0,A0,A0,29,50,30,20,
35,00,55,50,21,00,00,1A,00,00,00,FF,00,4E,41,0A,20,20,20,20,20,20,20,20,20,20,00,00,00,FD,00,17,
4C,0F,63,19,00,0A,20,20,20,20,20,20,00,00,00,FC,00,54,42,44,0A,20,20,20,20,20,20,20,20,20,01,16,
02,03,1F,F1,4C,01,02,03,04,05,07,90,12,13,14,16,1F,23,09,07,07,83,01,00,00,65,03,0C,00,10,00,02,
3A,80,18,71,38,2D,40,58,2C,45,00,FE,1F,11,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,FE,1F,11,
00,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,FE,1F,11,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,
00,FE,1F,11,00,00,18,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,E8,12,11,00,00,1E,00,00,00,00,00,00,07
And some more information...
Monitor
Windows description...... Boevt Terra2760WLED
Color encoding for...
ROBERT_U_Intel
@ Manbun
What type of HDMI cable are you using? Is it a High Speed HDMI cable?
From Wikipedia on HDMI:
As of the HDMI 1.4 specification, these are the following cable types defined for HDMI in general:
Robert
mlee56
Hi Robert,
I am using a high speed HDMI which i brought specifically for this.
I have also now had my motherboard replaced by Dell, which again hasnt resolved my issue.
Thanks in advanced.
Man-Bun,
ROBERT_U_Intel
All
We are working to locate one of the DGM displays. With similar display that I have to test with I am not seeing the issue.
Question, if the DGM is connected only to the HDMI output does it display native resolution? If it is configured as single display in graphics properties does it display native resolution? And is your MacBook running IOS?
Robert
mlee56
Hi Rob,
Please find testing below.
Set-upResolutionOSMonitor (DGM) - Connected via mDP Resolution 1440p @ 60 Hz Windows 7 & Windows 8.1Monitor (DGM) - HDMI - extend display + Laptop screen1080p Windows 7 & Windows 8.1Monitor (DGM) - HDMI - Single Display1080pWindows 7 & Windows 8.1Monitor (DGM) - HDMI + Monitor (DGM) - mDP1440p (mDP) 1080p (HDMI)Windows 7 & Windows 8.1Monitor (DGM) - HDMI - extend display + Laptop screen1440pMac OS X 10.9.4Monitor (DGM) - HDMI - Single Display1440p (HDMI)Mac OS X 10.9.4Monitor (DGM) - HDMI + Monitor (DGM) - mDP1440p (mDP) 1440p (HDMI)Mac OS X 10.9.4
I have also been advised on another forum the problem maybe to do with "HDMI often has a 165 MHz pixel clock limit, but 2560x1440 @ 60 Hz requires 241.5 MHz" - This doesnt explain why RZO is able to achieve the native resolution @ 60Hz using LINUX.... if i set the resolution to 2560x1440 @ 40 Hz using customresolutionapp i get a blank screen.
Hope with this extra data a solution is found as I currently have two of these monitors side by side with different resolutions.
cheers
MB
RSanc13
Hi Rob, I'm going to copy Bun's format for my own response.
Monitor (DGM) - HDMI - extend display + Laptop screen1440p Various Linux distributions including Debian, Ubuntu and variants of Ubuntu.Monitor (DGM) - HDMI - Single Display1440pVarious Linux distributions including Debian, Ubuntu and variants of Ubuntu.
I don't have another cable to try HDMI out to DP in, or VGA out to VGA in, so unfortunately I'm not much use there. As you can see extended displays on Windows give me two resolutions of 1080p. Setting the DGM as the only monitor (which disables the laptop screen) under Windows still only gives me 1080p. However, on Linux the full 1440p is doable in both configurations.
If there's any Linux diagnostics you want me to run to see what's different between Windows and Linux let me know and I'll see what I can do.
ROBERT_U_Intel
Thanks folks for checking and providing the additional information, it is very helpful. We are currently investigating this to determine the cause and will report back to this thread.
Robert
mlee56
Hi Robert,
Is there any news on this?
MB
ROBERT_U_Intel
We are still working on a resolution for the issue. Please watch this threads for updates.
Robert
VMurt1
I am also experiencing this issue.
Unfortunately, it looks like these links are broken. When I try to download the latest HD 4600 driver by searching the Intel Download Center, i find a download for version 15.36.18.64.4156. However, this will not install on my Dell Precision M3800 as the software reports that I need to install a version directly from the manufacturer. Dell is only offering version 10.18.10.3993, which appears to be very out of date.
Please advise.
VMurt1
Thank you for the updated links. Unfortunately, this will not install on my system as it says it is not validated for this computer and that I should seek out a driver from Dell (the manufacturer). Dell's version does not appear to address this issue.
Any suggestions?
