22849 Discussions
Dell XPS 14 (L421x) + Intel HD 4000 + Windows 8.1 - Brightness control problem
DNiki
I've got the problem with brightness control on my laptop. Now it's only 100% brightness and all methods from this forum or other else doesn't resolved this issue.
When I try to increase\decrease brightness (Fn+F4 \ Fn+F5) - it's changed only in Windows settings (see attached fig.1)
1. Adaptive brightness in Windows Power settings is SWITCHED OFF.
2. When I choose the Default Windows video driver - brightness control works perfect.
3. With Windows 8 and old Intel driver - it was worked, but now it's Widows 8.1)
So, I'm sure the issue with Intel HD 400 drivers. Please help me to resolve!
Configuration:
Dell XPS 14 (L421x)
Intel HD 4000 driver 10.18.10.4061
Windows 8.1 x64
Jose_H_Intel1
Hello dinikitin, did you try the drivers provided by DELL*?
DNiki
Hi Joe,
Sure, earlier I had installed the driver from support.dell.com -- Video_Driver_VJH9H_WN_10.18.10.3262_A00.EXE
but it's the same issue... As I remember I had no problem with that driver on Windows 8, but now I'm using Windows 8.1... So...
Can you help me?
Thank you.
glussier
For the Fn+F4 and Fn+F5 key combination and all other Fn+Fx keys, the problem is not with the graphic drivers but with the Dell quickset app. If it's not installed go to the Dell download site for your laptop and download/install the quickset application.
DNiki
The problem not in Fn+ keys combination. When I'm trying to change brightness in Windows Power plan menu - seems the same issue, doesn't work... And please read my first message: when I change the 'Display Adapter' settings to Default Windows adapter - the brightness control works perfect!
So, can anybody help me?
Jose_H_Intel1
I see your system has switchable graphics. It will be better to use the drivers provided by the manufacturer because some of these features are only available with the driver from the OEM. I suggest installing Intel® HD Graphics driver first and Nvidia's (or any other third party) second.
If the issue persists I recommend contacting DELL* for assistance.
http://www.intel.com/support/oems.htm Computer Manufacturer Support Web Sites
JHern27
I am having the same issue on a Lenovo Thinkpad W540 running Windows 8.1. I updated the Intel HD Graphics 4600 driver to the latest on the site (10.18.14.4080) and still no luck. Going through Charms -> Settings -> Brightness doesn't work nor does the hardware brightness buttons. I am however able to adjust it using the Intel HD Graphics Control Panel.
DNiki
Hi JesseH,
Can you please describe me how you adjust brightness through Intel HD Graphics Control Panel?
Thank you.
JHern27
Sure if you right click on any empty space of the Desktop select "Graphic Properties". Once you do that the Intel HD Graphics Control Panel should open up. Click Display then click on the Color Settings tab. Underneath that you should see the Brightness slider.
JReyn7
Intel HD Graphics 4000 and Windows 10 & Windows 8.1 ( Brightness fix with latest driver)
Brightness Fix with Driver Date 8/17/2015 )
Brightness problem Solved
Intel HD Graphics 4000 with NVIDIA® GeForce® GT650M graphics.
Install:
Intel HD Graphics 4000 Driver, Driver Date: 8/17/2015
Driver Version: 10.18.10.4276
Make sure you backup your registry first before proceeding!!!!
open regedit in Run Command
Registry has wrong value:
Currently reads as :
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000] "FeatureTestControl"=
"Edit DWORD 32 bit"= f000
Registry with New Value:
You needed to change the value in registry to: ( f008 )
"Edit DWORD 32 bit"= f008
Then Restart Computer
Brightness Fixed with Latest driver.
Let me know if this was helpful to you
mailto:jrreyn02@outlook.com jrreyn02@outlook.com
