H there, can someone tell me whether it is possible to disable v-sync on my Dell latitude 3420 with Iris Xe integrated graphics? In Intel Graphics Command Centre there is no option to disable V-sync, just a greyed out option to select adaptive sync. I need to disable v-sync to reduce input delay on PES 2017. I will try scanline sync instead. I have attached photos of the specs and issue.
Hello JaydenWell,
You can try these steps on how to disable Vertical Synchronization on your system:
Intel® Graphics Command Center (Intel® GCC)
VSync can be set to Always On, Always Off, or Application Controlled.
In order to configure VSync in Intel GCC, follow these steps:
- Open the Intel® Graphics Command Center:
- From the Windows Start Menu, search for Intel Graphics Command Center. Click the Intel Graphics Command Center icon to open the application.
- In the Home tab, select the game or application listed under My Games to edit the settings.
Note: If the game does not appear under My Games, add the game by following the steps provided in Solved: how to add games in intel graphics control panel gaming section - Intel Community
- Click Custom to create a custom profile.
- Find the Vertical Sync setting and apply the desired setting for the game or application.
Note: Always On sets VSync to always enabled. The Application Controlled setting sets VSync under control of the game or application that uses it.
VSync settings only affect full screen games or applications.
Intel® Graphics Control Panel
You can enable or disable the option for VSync in the game or application if the option is supported. In this version of the Intel® Graphics Control Panel, there are no options for disabling or enabling VSync for DirectX* games or applications.
Let me know if this fixes your concern.
Earl E.
Hi JaydenWell,
I wanted to check if you had the chance to review the questions I posted. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
Hi JaydenWell,
Earl E.
